Question about PC Chips (M925G) Motherboard
Im lost i was kinda bankin on xp auto formatting, how will i format this drive manually?
  • Anonymous Aug 11, 2008
    very thourogh, thank you
  • 781 Answers
When windows boots from cd so you can install it red the instructions carefully one of the pages it comes up with is
(What do you want to do)
R for repair
another letter for fresh install
then it asks you where you want to install press the letter indicated
new page
asks do you want to format press F then when asked follow instructions from there D for deleting partition F for formatting etc.
when formatting choose ntfs quick format
Hope this helps
Posted on Aug 05, 2008
SOURCE:
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
Cannot format hard drive on my T40. How can I tell
Depends on what kinda format u doing..if it's thru the XP Disk ..if it is stuck at certain stage for too long and can hear rattle sound near the HDD ...it's mostly HDD error..Try dos format using dos bootable...or i would try installing Windows NT old version and upgrade..it helps huge some times..hope this is help full..good luck..cheers
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
Hi im keki
right click on the HD icon in "My Computer", click on "format...," then read what's in the pop-up window. Kinda a hard within XP if it's the system disk.
or
E:\format e:\
(e = the drive letter to format)
Jul 14, 2009 | Sony VAIO Pcg-Z505LE Notebook
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate satat error
the firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Lost files
it depends if you formatted the hard drive you would probably... if you didn't you are lucky because you can probably find most of your old files under C:\documents and settings
if you did indeed format your hard drive, you may have to spend hundreds if not thousands on data recovery, im sorry that as far as that goes im not sure what company or service can guarantee your files back, i don't know which to refer you to.
Dec 28, 2008 | Dell Inspiron 6000 Notebook
Auto format new hard drive in new custom pc
If you mean boot from cd with xp pro during setup you will have the opportunity to format drive either fat32 or ntfs use ntfs
I have never done it but if you can do it partition your hard drive so that you can save personal file and programs on second partition then if you have to format drive again your files on second partition will not be lost
Aug 04, 2008 | PC Chips (M925G) Motherboard
512MB KINGSTON DATA TRAVELER BECOMES SKYMEDI USB DRIVE USB DEVICE..PLS HELP
I think that I have a similar problem (and a potential solution)
1. My thumb drive is 4GB "super talent", and I have used it for about 2years
2. Suddenly, it show up as "REMOVABLE" SKYMEDI USB DEVICE (!)
3. I tried "google" for answer... and did not get further
4. Finally, I righ click on "my computer" -> select "manage" the "computer management" MMC windows open
4.1 I tried the "Disk Management" and it still can not connect to it
4.2 I clicked on "Removable Storage" ... and then I "SKYMEDI..."
4.3. I righ click on the device and select "Task" -> "Free" (thinking ... what can be worst!)
4.4 ... sunddenly ... I see my drive back ... with everything on it....
I hope that this help (... I am guessing that the "removable storage" manager locked this device somehow)
Regards
Jul 07, 2008 | Kingston Technologies 512MB DataTraveler I...
Uninstall xp
You can remove service pack 2 from within add/remove programmes, you will not lose any documents, but you will lose the udated security patches which is not recommended. If you mean you wish to remove XP SP completely, obviously the files and everything you have installed on c drive will be deleted as you can only save docs etc within an operating system, as c: is just a partition on your hard drive the files reside within the operating system. If you are upgrading to another operating system my advice would be to use a dual boot system and install the other operating system on a seperate partition of your drive, but you would have to have a fair knowledge of pc operating system installation processes.
Oct 03, 2007 | Microsoft Windows XP Professional With...
PC Chips (M925G) Motherboard Logo
71 people viewed this question
Top PC Chips Computers & Internet Experts
Thomas F. Schneider
Ekse
Alun Cox
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
