Using a4tech G6saver mini wireless desktop keyboard and mouse, model GK-520D. RF receiver and mouse working ok. Green LED on rcvr blinks when mouse moved. Cursor moves on screen. Keyboard not communicating with receiver. No LED blinking when keys depressed. No characters show on screen. Replaced batteries in keyboard, no luck, Pressed Connect button on bottom of KB but no luck. KB and mouse have been working fine for about 4 months. Now no KB. Suggestions? Thanks, Bob Tellefsen
  • n6wg Apr 03, 2011
    Ezrahite
    I have replaced the batteries in the KB with no result.
    I'll be taking the KB back to Fry's to see if I can replace it with
    another, or get a refund. I really like the KB, but can't afford
    one that fails easily.
    Thanks,
    Bob Tellefsen
  • 2,632 Answers
Welcome to Fixya. Since the mouse is communicating with the RF receiver it seems that there is no problem with the receiver of the GK-520D. The things that you need to look into is the battery and the sensor of the keyboard. Make sure you replace it with a fresh battery and press the connect button light should lit up as it connects. However if it will not respond on the receiver after pressing the reset button most likely that the sensor of the keyboard is not working. Im not sure if the warranty of the mouse and keyboard is for a year but if it does then you need to ask for replacement for it.
Thanks
Posted on Apr 03, 2011
  • Rofel Lantican
    Rofel Lantican Apr 03, 2011
    Not a problem Bob. Yes you can bring back the KB to Fry's and see if they can replace it. The Keyboard is good specially it is connect to an RF receiver. If you have questions please let me know ok. Thanks for using Fixya
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Keyboard Model GSK-5 is not owrking although mouse is working. It happens after the installation of new windows. Although I have changed batteries but no avail.
Hello I have lost the reciever of a4tech model= GSK-5
if some one is able to help me please contact me at these ids
aftigher1876@gmail.com
Sep 15, 2010 | A4tech A4 tech G6 saver Mini Wireless...
Keyboard not responding. just bought it today.. i've check everything, battery, drivers and receiver are all ok.
After six months of using the same keyboard / mouse combo with no problems, I had exactly the same problem as you one day (keyboard wouldn't connect, but mouse OK), I resolved it by powering down the mouse (hold the 'connect' button) and then sync-ing the keyboard using the USB key. When I powered the mouse up again, both pieces of equipment worked fine again. Hope this helps.
www.myspace.com/misnomeruk
Apr 24, 2010 | A4tech A4 tech G6 saver Mini Wireless...
My Kensington wireless keyboard (Ci70) just stopped working. I have no idea why. The mouse works just fine. XP Pro SP 3. Have rebooted. Unplugged the USB interface device. Plugged back in. Rebooted....
Replace batteries in keyboard and re-sync the devices
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Synching Mouse or Keyboard with Wireless Optical Desktop trnsp.gif Question My mouse or keyboard doesn't work with my Wireless Optical Desktop (Model Number: 64373). What's wrong and how do I fix this problem? trnsp.gif Answer Your mouse or keyboard has lost its sychronization with the Wireless Optical Desktop, which can occur after changing the batteries, for example.
To synchronize your wireless device with its receiver:
  1. Move the device within three (3) feet of the receiver.
  2. Press the button on the receiver.
    If the receiver has an LED, the light blinks.
  3. Within ten (10) seconds, press the button on the underside of your wireless device.
    If the receiver has an LED, the light glows solidly when synchronization is successful.
Early production units of some wireless devices may require repeating the above instructions two or three times.
Timing, distance, and objects impeding the wireless signal may influence your success. While usually unnecessary, some customers have reported better results by:
  • Holding the wireless device very close, within three (3) inches of the receiver.
  • Entirely ignoring the receiver's light.
  • Simultaneously holding the buttons on both the receiver and the device for from ten (10) to twenty (20) seconds.
Dec 12, 2009 | Kensington Computers & Internet
Receiver for my RF wireless deskset is flashing constantly
If the mouse and keyboard are working, and the receiver is still flashing constantly, then it's probably just indicating that the receiver is connected to the keyboard and mouse.
Jul 06, 2009 | Micro Innovations PD7250LSR Wireless RF...
Keyboard works, mouse not
Are the batteries in the mouse charged?
If you are not using rechargable batteries replace the batteries with alkaline batteries, they only last about 1 month...
Jun 28, 2009 | Labtec 9675120403 Keyboard
Manual for A4Tech RK(s)-520D wireless keyboard
1. Go to: http://www.a4tech.com/ennew/downloads.asp
2. Under the "Downloads" section, you will find 2 fields. Click the arrow next to the field labeled "SELECT" & choose "RK(S)" from the drop-down menu. The second field will display "130MG". Click the arrow next to this field & select "520D" from the drop-down menu.
3. Click the "GO" button.
4. In the next page: in the orange side-bar to the left you will find your Keyboard/Mouse combo model & 2 buttons. Click the button labeled "Product Manual" to start the download.
Jan 11, 2009 | Gateway 2520915 Keyboard
Bought two Sakar I Concepts wireless keyboard/mouse last summer at walmart and kept them to give as Christmas presents. I have found out from both people that I gave them to that the mouse works on both of...
I've used the 62150 black combo (not 62150N Deluxe silver) on XP Pro for years with no problem. Manual said to sync, press ID button on receiver and LED will blink fast, then slower. While blinking, press ID button on keyboard and mouse (need pen or something to press mouse button). If receiver LED blinks whenever you move mouse or hit keyboard, it is receiving. If OS doesn't recognize, may be connectors. I had 2 separate PS2 ports and had to use an USB adapter for the keyboard cable.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
