What you will need to do is go from the bottom up with a sturdy metal rod with a 90 degree bent end and try to release the latch. This will probably take some time as room is scarce. If you are looking from the bottom up, the latch release is towards the middle left of the white plastic coolant reservoir tank. You will need to try to push it towards the drivers side.
Hello. Usually when you raise your hood look to the left or over to the passenger side against the side wall there will be a blue cap covering the washer fluid tank remove it fill the the tank and snap the lid back into place.
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
the 3800 v6 motors have the reservoir on the power steering pump - if looking at motor drive belt - alt on top of motor back toward windshield - p/s is at bottom of motor toward windshield - lean over motor or slide arm down around alt. - when not running and not hot - unscrew cap - funnel will be needed if fluid is low
Low coolant level, failed thermostat, blocked radiator core or failed pump are all possible causes. Check them in the order given in the list as they become more complex and expensive to fix. Coolant level is easy enough to check, if low just top up at the reservoir. Whilst doing this check that the relief valve in the cap is OK and that the filler cap sits tightly when screwed down. For the thermostat drain the coolant (should be a bled valve for this purpose towards bottom of radiator) into a bucket and remove the 'stat housing and put the 'stat in a pan of simmering water. The 'stat plate should open up about 5mm. Take the pan from the heat and add cold water and the 'stat should close after about a quarter volume of cold water has been added. If the 'stat fails to open or close then replace it. Whilst the system is drained of coolant remove the top and bottom rubber hoses from the radiator. With a hose flush water into the top radiator opening and check if water exits freely from the bottom of the radiator. If there is a sign of blockage put the hose in the bottom opening and put the water on full pressure to back flush the radiator. Keep doing this until the water is clear. If everything up until now has been fine the last thing to look at is the water pump, either the pump has seized or there is a fault with impeller. When refilling the coolant system after any repair make sure that the interior heater is on maximum. When warming the engine up keep the heat on maximum and this will help displace air trapped in the system. Whilst warming up squeeze the radiator hoses regularly again to keep bubbles moving towards the reservoir filler. Keep the reservoir topped up as air bubbles work their way out. Only when the engine is nearly at running temperature tighten the filler cap. After having driven the car, let it cool off and check the coolant level, again top up as necessary.
Hello: The power steering pump and fluid reservoir sit on the top of the engine toward the radiator on the passenger side, there should be a cap on top in back of the pulley that will come off, on the bottom side of the cap there is a dip stick, fill the reservoir to the line on the cap. Use power steering fluid, DO NOT USE ANYTHING ELSE.
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
