Question about Canon Office Equipment & Supplies
I recently started using Juno DSL, and I connected Canon Multipass C3500 to Phone wall jack as instruced amd to LINE of C3500, but when I receive a phone call, C3500 rings, too, even I set it FAX/TEL mode. I connect C3500 PHONE to PHONE jack of my PC. Is my connection wrong?
    President:
  • 2,712 Answers
Check ur connectoins..call ur service provider for proper details.
Posted on Aug 08, 2008
Canon Fax Instructions
You may download the manual and more from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx892#BrochuresAndManuals
How do you have DSL without a landline? Are you able to make and receive phone calls? If so then the fax should work just fine. It doesn't matter to the fax machine if your phone jack is connected to old-style copper wire, DSL, or fiber-optics. On the other hand, if you can't make and receive phone calls then you can't send and receive faxes either.
May 17, 2013 | Canon Pixma Mx892 Inkjet Multifunction...
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
What to do if dsl light is blinking
This likely means that your DSL modem is not trained up with the DSLAM. - Geek talk for your modem is not connected to the phone company's equipment properly.
1.) Remove power from the modem
2.) Remove all devices (including the DSL modem) from all phone jacks in the house.
3.) Add the DSL line back to the wall jack, taking care to plug the wall jack into the correct jack on the DSL line. (Do not use a DSL filter on your modem!)
4.) Power up the modem/
Still not working? Continue...
5.) Try a different phone jack
6.) Try a new phone cable between the wall jack and modem
7.) Call the phone company for further assistance.
Dec 18, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Need a manual for canon multipass c3500
You can download manual here
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
regards
Sep 04, 2009 | Canon MultiPASS C3500 All-In-One InkJet...
Cordless phone has volume problems with DSL
For starters that dsl modem should not be filtered.
You should place the splitter directly into the wall jack and place the filter on the side used for the phone. The side feeding the dsl line should not be filtered.
The filter serves 2 purposes. 1 it reduces data noise interference onto the voice line. 2 it prevents dsl interference from voice such as picking up and hanging up the receiver.
Aug 26, 2009 | Uniden Cordless Phone
How do you receive fax on hp officejet 4110
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Jun 19, 2009 | HP Officejet 4110 All-In-One InkJet...
Lose DSL connection when tv is turned on.
If there is a filter on BOTH ends of the phone line that is the problem. There should only be one plugged into the wall. Take the phone line and plug it into the phone side of the filter. The end that plugs into your receiver should never have a filter on it. Also I've never heard of a receiver needing to be connected to a phone line AND a router. You usually only need one or the other but not both.
Dec 19, 2008 | Siemens SpeedStream (SS3060) DSL Modem
I have a Canon MP830-All in one. It does everything except send/receive faxes. The line has been checked out. If I connect it to the phone line, it just clicks. I have rebooted and unplugged and...
Your fax machine is not getting a dial-tone.
Plug a regular phone into the wall jack and listen for a dial-tone
Make sure the phone line is hooked into the LINE port of your fax machine.
Unplug the power cord for 10 seconds.
Do you have a DSL phone line?
Oct 21, 2008 | Canon Office Equipment & Supplies
Connection of Canon Multipass C3500 to Juno DSL phone line.
Read the instructions again again...u probably got it set up wrong..
Aug 08, 2008 | Office Equipment & Supplies
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
May 09, 2008 | Computers & Internet
old marine
old marine
