Question about Air Conditioning and Heat for GMC Acadia
2011 brand new GMC acadia slt - ac will not engage at all - tried auto and manual settings - just flashes 3 times and nothing
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Brand new no warranty?
Posted on Apr 24, 2014
I just replaced front brake pads myself. 65K Miles. Rotors were fine. Now that everything is back together the Acadia bounces down the road at any speed. What did I do wrong?
bounces or wiggles ?? as if it wiggles then you've missed a warped rotor by not changing em ,(there can be more wrong with rotors than just physical wear ) this will make your front wheel bearings go bad early if you allow them to wiggle this way BTW if you change rotors its a good idea to at least regrease bearings if not replace em , and allways get new grease seals don't try to reuse em
Feb 29, 2016 | 2011 GMC Acadia SLT-1
Want shift into hi gesr
Search Results
    New owner of 03 Envoy XL SLT - AC not working - Chevy TrailBlazer ...
    forums.trailvoy.com > ... > OEM Issues
    Apr 12, 2011 - 11 posts - ‎5 authors
    My Envoy XL SLT has the I6 engine, digital driver/passenger, and rear ... It still doesn't appear that the AC compressor is kicking in. ... 2004 GMC Envoy SLT XUV ...Obviously if failed open the clutch won't engage. ... turn on the a/c and watch to see if it give the hint of wanting to go, if it .... Security Question ... A/C compressor not engaging
    Aug 25, 2010
    Removing front differential!!
    Mar 1, 2010
    [SOLVED] Trailblazer stalls at idle when defrost or A/C ...
    Jan 21, 2010
    Check A/C how?
    Sep 16, 2006
    More results from forums.trailvoy.com
    GMC Truck Repair Question Forums - GreatAutoHelp.com
    www.greatautohelp.com/gmc-trucks.php
    runs fine in park or at idle. go to put the truck in gear and it stalls out, will not take a ...What is OE thermostat temp suppose to be for a 2003 gmc envoy with the 4.2. ...signal for the injector to open and let fuel into the engine. to check the injector pulse..... Any idea on the issue. RPM stay the same when it idles rough. 4.2l v6 ...
    4.2L Inline 6 Cylinder 4200 Engine Sensor Location Pictures
    www.greatautohelp.com/sensor-location/4200.html
Jan 24, 2016 | GMC 2004 ENVOY XUV A/C Compressor a1z18717...
Where is the 2008 Acadia throttle body sensor?
The Internet has a large number of web sites
where you can buy service manuals and schematics
from bookstores, publishers, and other collectors.
Factory Auto manuals
http://www.factoryautomanuals.com/
search for : factory service auto repair manuals
Repair Service auto Manuals
where to buy Factory Service Auto Repair manuals
http://www.repairservicemanuals.com/
the largest collection of Automotive Repair Service
Manuals and Owners Guides on the internet. Our
database currently holds over 54,000 entries dating
back from 1940 to more recent 2011.
Chilton Repair and Service Manuals
http://www.chilton.cengage.com/
Haynes Repair and Service Manuals
http://www.haynes.com/
Jan 17, 2016 | 2008 GMC Acadia
2009 gmc acadia replace rear brakes
this is on a bigger truck but its the same procedure for changing your brakes if you dont have a piston tool you can use a c-clamp with an old pad to depress piston (s)back or most auto stores will let you borrow tools
Yahoo Web Search
Aug 07, 2015 | 2009 GMC Acadia SLT-1
Why doesn't the air conditioning work?
Apr 12, 2011 - 11 posts - ‎5 authors 2003 GMC Envoy SLT XL Summit White ... My Envoy XL SLT has the I6 engine, digital driver/passenger, and rear heat/AC controls. When I looked at it, .... There have been reports of failed sensors in the compressor. Can you ... [SOLVED] Rear A/C blower 03 Envoy XL
May 22, 2011
XL rear a/c problem - Chevy TrailBlazer, TrailBlazer ...
Jul 31, 2009
Air Conditioner Problem - Chevy TrailBlazer ...
Aug 17, 2008
Blower Motor/Module? Problem - Chevy TrailBlazer ...
Mar 9, 2007
Jul 18, 2015 | GMC 2003 Envoy XL SLT
I have gmc acadia 2009 and at 45 c outside tempreture the compressor will not engage and when i bush the cooling botton it will blink 3 times and the ac will not cool ,, note that at cold condition the...
At 45 F that is just 12f above freezing and it is possible that the thermostat inside the car is turning the compressor off as it is intended to do. I suggest that you take it to an accredited ac specialist shop for pressure test and thermostat setting test.
Jul 25, 2014 | Cars & Trucks
Lumber support won't inflate..
It does not inflate. It uses an electric motor that pulls a spring together. You need to remove the seat back and check it for power and ground signal but it is most likely broken and needs replaced
Aug 28, 2013 | 2011 GMC Acadia SLT-2
What's your problem?so a few days ago on my GMC Acadia 2008 SLE the panel where i control the AC/Heater stopped working, the display is on, but the buttons are not working and dont light up, does
You might just have a wire loose somewhere. My 96 Cadi did that a couple of times lastyear, then it was fine. Hasn't done it since.` So, who knows! Sorry, not much help to you.
Feb 08, 2013 | 2011 GMC Acadia
Low beam headlights not working on brand new acadia
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Mar 27, 2011 | 2011 GMC Acadia
Air Conditioning and Heat for GMC Acadia Logo
135 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
