Question about TruTech Televison & Video
I borrowed a used TT 320 Progressive Scan Video Trutech DVD player from my neighbor today.I plugged it in &connected the color cables &everything.The DVD player turned on, but when I tried to play a DVD it wouldn't seem to play it &then after that I pressed the eject button to try to take the disc out,but the disc drive wouldnt open.I use an old I Insignia tv.It doesn't have cable I switch it to video on the tv to play DVDs.I basically need help getting my DVD player to work &play DVDs so Im able to watch movies.
snakehead
  • 1074 Answers
SOURCE: No color when watching a DVD
check your dvd if it is not on PAL if it is then switch it back to NTSC.if that does noe work then call tech to look at your dvd.and tv.good luck
Posted on Apr 22, 2007
HDTV GURU
  • 261 Answers
SOURCE: DVD player not working
It could be that the DVD player has a bad home switch in the dvd player or that it doesn't know that the door is closed. I have run into similar situations with CD Players years ago. Also keep in mind to unplug unit and let sit for 1 minute to let microprocessor reset. Let me know if that helps. Thank you ...Jay
Posted on Jan 31, 2008
SOURCE: No surround sound when watching TV
hdmi can only pass pcm 2.0 digital for the separate cables you may try to switch them to another output from the monitor to the receiver or if you can get your hands on a spd-if cable (one single fiberoptic cable that will go as high as 5.1 dolby surround)
Posted on Feb 01, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
CRTN
  • 716 Answers
SOURCE: How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Posted on Jan 05, 2009
DVD player-ND-861. Why has it started showing videos in black and white instead of color?
If you are using this with a cable that has just yellow for video, and red and white for audio, you may have inadvertently put the DVD player into the progressive scan mode. Some DVD have a button on the remote that actually says progressive scan. Find you instructions to change to composite mode versus component. If you use a five wire cable then place the DVD into the progressive scan mode.
Oct 11, 2017 | Televison & Video
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Mar 26, 2010 | Panasonic SC-HT730 System
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Progressive Scan
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Jan 04, 2008 | Zenith XBV442 DVD Player/VCR
Progressive Scan
Please go to the following link for an exact definition and how it is applicable to your situation. Please read all 3 pages of information!!!!! The short of it is, is that your TV may not be set up for progressive scan. Try turning off progressive scan on your DVD player's menu and see if this works.
http://hometheater.about.com/od/beforeyoubuy/a/progressivescan.htm
Jan 03, 2008 | TruTech TT1620 DVD Recorder
No color when switching to component cable
To Change DVD Player Video Output to Progressive Scan: With your DVD Player turned on, and your TV turned on, press and hold the PREV/VIDEO button for at least 3 seconds (this puts you into Video Output mode). Press the PREV/VIDEO button to access different video output options. Each time you press
PREV/VIDEO, the type of video being displayed appears next to the Display menu. Look for PSCAN on your DVD player display panel. At this time, your progressive scan on TV should be working.
Oct 18, 2007 | RCA DRC233N DVD Player
Televison & Video Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
