Question about Nordic Track C2255 Console (treadmill)
Nordic Track C2270 Console Problems I have a C2270 which has been perfectly fine until recently. When I go to use it lately, only three or four of the buttons on the console are working (3mph, 8mph, 12mph, none of the function keys). I played around with it and got it to work for about a week, but now it's back to the way it was. I changed apartments awhile ago, so I'm hoping that a connection may have just been jostled around. Is my console shot? Is there a diagram somewhere of the console's electronics?
    Guru:
  • 1,833 Answers
You can try with this solutions : first remove the console and remove the back of trademill. remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console reattach the console, now With the key off press the speed + and stop buttons at the same time and hold, place the key on and release the buttons, press the stop key once, press the speed up til it reaches 85. If it doesn't work then you have to replace your console.
Here are some web links where you can find diagram of console : http://nordictrackparts.com/diagram/7187,
http://www.searspartsdirect.com/partsdirect/part-model/nordictrack-parts/treadmill-parts/Model-NTL12952/3016/1307600.
Posted on Apr 04, 2011
I have a Nordic track EXP 1000 the only keys that work are the start button and 1 mph. Other than that nothing else works. Not sure if it is the controller or the council. Any suggestions?
I had the problem years ago and I contacted NorcTrack and their solution was to replace the entire console for about $400. They wouldn't replace the pads or anything else, all they would do is sell me the new console. That was not going to happen since I had only had the thing for about 5 years at the time. I wasn't going to be putting that kind of money into that treadmill every 5 years or so.
I tried many things and I finally decided to buy a new console pad from the Treadmill Doctor. I think it was around $100. It was easy to replace. I just removed the screws holding the console cover in place, unplugged the wires leading to the lower console pad and pulled it off. The new pad fit exactly into the space the old pad occupied, I plugged it in and it worked. It's still working about 6 years later. I use this treadmill daily without any problems. It's not anywhere near as nice as the new units I see out there today, but it does what it's supposed to do and that's all I need.
The Treadmill Doctor has all the parts you need for this machine at a reasonable price. Much cheaper than Nordic Track.
Mar 15, 2014 | Nordic Track Nordictrack Exp 1000...
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
Belt on Nordic Track T4.0 treadmill stops
Dear Sir:
1) Lube the treadmill in according with the instruction manual.
2) The reason is lack of lube by maintenance, that produce enough friction with shut down for to protect electronic system.
3) Test the deck belt if is worn, and replace it.
4) Test the rollers bearings
5) See the bearing motor
6) Test the input voltage motor coming from the output from the main motor board,, use DVOM.
7) See my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Nordic Track Exercise & Fitness
My C2255 Nordictrack has been fine for the past couple of years until recently when it started turning off intermittently with no power to the console. Now, the console will not turn on at all. The...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Oct 17, 2011 | Nordic Track C2255 Console (treadmill)
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Jan 12, 2010 | Exercise & Fitness
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Jun 08, 2009 | Exercise & Fitness
Nordic Track C2255 Console (treadmill) Logo
1,218 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
