Hi , i have just purchased a Rowe AMi R92 jukebox , could you tell me how to put it on free play please .???
4 Suggested Answers
  • 195 Answers
SOURCE: We have replaced the 3 volt battery and now we
Hi Ponorosa42,
Do you have the manual for the Rowe Ami R-92?
If not then you need to get one in order to set each location in the menu.
The manual can be purchased in a paper form or on CD from a number of dealers on Ebay.
The paper manuals can be purchased from www.victoryglass.com also a good source for spare parts.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Posted on Oct 05, 2009
SOURCE: Hi' I have just got a rowe ami r-83 disco jukebox.
you need to check the Home signal to make sure the opto is activated at position 99. When the unit powers up the mechanism scans one complete cycle so it re-indexes the computer and starts scanning from position 00. If you want a quick test, turn the power off and scan the carousel to position 99 by releasing the latch on the left side of the mech just under and behind the mechanism motor. then power up the unit and it should pick the right selection. You can also observe the optic indicators on the mechanism control board under the turntable. The Home signal only operates at 99, the Index pulses between each record as it scans. Good Luck
Posted on Dec 02, 2010
  • 22 Answers
Replacing the battery should have reset the computer to "factory defaults". If the computer worked before the battery change, it should have just worked. No PROGRAMMING is needed for it to function. Check the following.
Make certain that you have all of the plugs reconnected through out the entire machine.
Check the plugs that you messed with.,Sometimes it is possible to have the plug off of one of the end pins It can appear to be plugged in but it is off by a single pin.
Make sure that you have all of the power indicators lit (LED's) on your power distribution unit.
Be sure that you installed the battery correctly. Sometimes the replacement batteries can have a different appearance from the original. You must look to see if the polarity of the battery is correct. The board & the battery should be marked. + & -..
Push on all the chips that are set in sockets. These can back out over the years. This is called "chip Creep"
Examine the board for poor solder, especially on the "plug" pins.
Also there are 3 (I think) electrolytic capacitors that you may want to change
If none of this gets you going, you may want to try try replacing the computer
Posted on Aug 29, 2015
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hi Ponorosa42,
Regards
Alan Hood
ami-man
UK
Aug 06, 2009 | Audio Players & Recorders
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Mar 10, 2009 | Wurlitzer Jukebox CD Player
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
155 people viewed this question
 Grubhead
Grubhead
