Hello, Our Sony TV KV28WF1B switches off automatically, and the led blinks twice. If you cut of the power for at least 5 hours then TV starts again. Somebody any idea what this is, is it easy to solve, what shall it cost and is it worth it. Thanks,
    Scholar:
  • 67 Answers
It sounds like a power supply problem. You need to check the capacitors on the power supply pcb. This is the board with the power cord connected to. If they are puffed up, you will need to replace the capacitors with equal or slightly higher values. The values are in mfd and voltage. It is printed on the caps. You will need to remove the back to get access to the pcb. To do this you need to lay the tv face down on a flat surface preferably on a table with a blanket for cushion. You need a table big enough to support the whole tv by the frame. This is to prevent damage to the panel. Then you need to remove all the screws securing the back to the frame. Give it a visual check and if the caps look good, then you need to check the voltage level on the outputs. These are printed next to about three connectors on the pcb in the same general area. If the voltage levels aren't there, check to see if you have standby boltage anywhere on the connectors, which should be 5VDC. You will need a multimeter for this. Connect the black lead to chassis ground and use the red lead to test for the voltage levels. If you have 5VDC anywhere, check a voltage output by placing the red lead on it and powering up the machine. If you have a momentary voltage value equal to the pin on the connector, then suspect the main board.
Posted on Apr 03, 2011
Red light is blinking 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 04, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
Jan 13, 2014 | LG 47LM6200 - 47" Class LED 3D Cinema HDTV...
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
Oct 03, 2011 | Dynex DX-L19-10A LCD TV
I need the set up code for a oneforall remote for a rca tv urc6012boo
Hello
There is no codes found in its user manual. Only code search process is given. We ahve to search and find the code of our device.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Jun 27, 2011 | Televison & Video
I need to know how to find tv codes by code search
Hello
[1] On the remote control, press TV once.
[2] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[3] Enter 9 - 9 - 1.The LED will blink twice.
[4] Aim the remote control at the TV and slowly alternate
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, UP or PLAY).
first.
[5] To lock in the code, press and release SET.The LED will
blink twice.
[6] To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
OK.
May 05, 2011 | One For All URC-3021 Remote Control
I need a sony cocde for blu ray model bdp-s270
Hello
BDP codes are not listed in one for all universal remote control URC-6131.
Just try searching for codes for you device.
If your device does not respond to the remote control
after trying all codes listed for your brand, or if your
brand is not listed at all, try searching for your code.
blinks twice, then release SET.
slowly alternate between pressing POWER
will send IR codes from its library to the selected
devices, repeat steps 1 through 5, but
I'm not sure weather you get your BDP code like this. anyway try. Best of Luck.
Ok
Apr 21, 2011 | Universal Remote Control URC-6131N Remote...
WHAT IS THE CODE FOR MY SONY TRINITRON T.V?
To control a Sony TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0000, 1100, 0810
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 04, 2009 | One For All URC-3021 Remote Control
Sony tv code from urc-3021gb1
1) Turn on your TV.
0000, 1100, 0810
Hope that helps.
Oct 21, 2009 | One For All URC-3021 Remote Control
I need the code for a phillips universal remote model CL034 to go with a durabrand tv?
Probably not going to find a specific code since durabrand is a walmart branded tv, your best bet is to try the automatic mode of your remote, or try different brands of tv, starting with sharp/sanyo/sony as those brands are ones that walmart sells most.
Sep 23, 2009 | Philips Universal PH301S Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
