Question about Plumbing
Installing a Delta RP1740C stem unit assembly in my two hande shower/tub unit the water tap will not shut off when installed. Do you have any suggestions?
2 Suggested Answers
  • 23 Answers
SOURCE: Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
Posted on May 12, 2009
All the faucets except my shower have hot water why doesn't my shower have hot water
your video doesn't show much of your shower for very long, but at a guess i'd say you have separate hot cold taps, in which case always turn on hot first then carefully turn on cold to ensure there's no issue with water pressure. if there no hot water running at all the hot water valve is faulty
Feb 07, 2013 | Home
The cold water on my Delta double hand faucet is leaking. I replaced the spring and rubber seat. when I put it back together, i can not turn the water off with the handle. I took the stem assembly out...
I believe they go in one way ,, but I've seen some that are 180 degrees out, which would make it so the water won't shut off, also with delta and moen,, add some plumbers grease to the o rings and faucet washers, so they don't stick when replacing,
Sep 28, 2011 | Delta & Stem Unit Assembly
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
No cold water coming out of bath/shower, only really hot water
Is it a Delta brand, single handle valve? If so, chances are you need a new "stem" and can be purchased at any plumbing suply store or home store. You will need to shut the water off to the house to do this (unless you are certain you know where the shutoffs are). Good luck
Sep 02, 2009 | Moen & One Handle Tub & Shower Faucet
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
May 09, 2009 | Delta Faucet Company Classic Collection...
Leaking water from tub spout
First you should obtain a parts brake-down instruction sheet, contained within the owners manual or downloaded from the manufactures website. With that you will have a detailed description of the removal and re-installation of that units cartridge, which upon removal you may see a build up of debris at the inlet ports or a ruptured O-ring in need of replacement.
Before any dis-assembly, turn off the hot and cold supply to the unit.
Good luck
Aduz
Mar 27, 2009 | Home
Plumbing Logo
284 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
