Question about Troy Garden
Model #52064 how to change oil cain't find where to open tp get oil out
    President:
  • Troy Master
  • 1,545 Answers
Most lawnmower (4 Stroke) engines like yours have a drain plug in the bottom of the engine. I realize your unit also has a pulley on the shaft, not a blade. Tilt the machine back (towards the control handles) and take a look at the bottom engine cover . You may find an inset steel plug that a 3/8" drive ratchet or extension will fit into. It will be square shaped. Insert your ratchet and remove by rotating counterclockwise. Your manual was no help here. Post back if no drain plug is found directly underneath the engine. There are other ways. Here is your manual also.
http://dl.owneriq.net/7/708a23e2-b160-4dc4-cd41-cf2a7176a94c.pdf
Posted on Apr 03, 2011
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
How do I solve for My Hyundai sonata model 2009 code P2110 , P2118 in scaning. I changed throttle body and TP sensor. after change of these even I am getting problem in accelerator not increases above
P2110...Faulty Throttle Actuator Control Module
- Throttle Actuator Control Module harness is open or shorted
- Throttle Actuator Control Module circuit poor electrical connection
P2118 - Electronic Throttle Control(ETC) system is made of the components throttle body, Throttle Position Sensor(TPS)1&2 and Accelerator Position Sensor(APS) 1&2. The throttle body contains the actuator, the throttle plate and the throttle position sensor (potentiometer), which are integrated in one housing. The actuator consists of a DC motor with a two-stage gear. The opening angle of the throttle valve is detected by the throttle position sensor which is mounted on the throttle body. And it provides feedback to the ECM to control the throttle motor in order to control the throttle valve opening angle properly in response to the driving condition.
Jan 06, 2015 | 2009 Hyundai Sonata
What dose it mean when engin light falshes contstantly
Flashing Diag Code P0122
TP circuit low input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 below 0.10 V after engine start, PCM determines
that TP circuit has a malfunction.
POSSIBLE CAUSE
• TP sensor malfunction
• Connector or terminal malfunction
• Open circuit between TP sensor terminal C and PCM terminal 89
• Short to ground circuit between TP sensor terminal C and PCM terminal 89
• Open circuit between TP sensor terminal A and PCM terminal 90
• Short to ground circuit between TP sensor terminal A and PCM terminal 90
• PCM malfunction
Flashing Diag Code P0123
TP circuit high input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 is above 4.77 V after engine start, PCM determines
POSSIBLE CAUSE
• Open circuit between TP sensor terminal B and PCM terminal 91
• Short to reference voltage (Vref) supply circuit between TP sensor terminal C and PCM terminal 89
• PCM malfunction
Jun 26, 2014 | 2000 Mazda Protege
I have set password for my TP-WR642G long time ago, but I want to change it. What can I do?
When you purchased your router, if It came with software then your going to have to use that. It should be as simple as opening the software, finding the setting and changing it. If not, your going to have to be an administrator on the network and go to network settings.
Aug 17, 2012 | TP-LINK TL-WR642G Router
TL-WR940N
Hello
I can give some details on port forwarding for TL-WR940n. You could follow this procedure given below. here is the link too. http://www.tp-link.com/en/article/?id=72
How do I open ports on my TP-LINK wireless Router?
Suitable for: 300Mbps Wireless N Routers, 150Mbps Wireless N Routers, 54Mbps Wireless G Routers
Step 1 Open the web browser and type the IP address of the router (default is 192.168.1.1 or 192.168.0.1) into the address bar and then Press Enter.
Step 2 Type the username and password in the login page, the default username and password both are admin.
Step 3 Click Forwarding->Virtual Servers on the left side, and then click Add New... button.
Step 4 Type the Service port which you want to open and the IP Address of your computer; Select Protocol to TCP, UDP or ALL; Change Status to Enabled
Step 5 Click Save button to save the settings.
Note:
If you want to open port 80 for Web server in your computer, the Management port of the router will be changed to 8080, you need to type Http://192.168.1.1:8080 to connect to you router.
TP-Link_SupportForce
TP-Link USA Corporation
Tel: +1 866-225-8139
E-Mail: steve.crow@tp-link.com
Website: www.tp-link.com/en/support/index.asp
Jun 08, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
On the book of Genesis explain God's "Creations" and Put in Adam & Eve and they brought a family for the begining as I understand, thay were the first man and women were put on earth, then...
The Bible does not tell us where Cain's wife originated from. But, what we are aware of is that God could have manifested this woman from dust as He did Adam.
Jan 04, 2011 | Ford F-450 Cars & Trucks
What Cain of oil use the Honda Passport 98?
20/50 cheapest you can get and change every 6000miles ,with a oil filter every third oil change
Mar 25, 2010 | 1998 Honda Passport
Trying to secure my tp link router
You need to access your router setup and admin pages.
At START, RUN, type in CMD. This will open DOS dialog box. at the >prompt, type ipconfig. Look at the data returned, Your are looking for the Default Gateway. It will be like 192.168.1.1 or some other sequence.
in your browser's address bar, enter this number. This opens the router set up/admin page. default login should be user:admin, password:admin.
I don't have the model number of your TP Link router. Find yours at TP Link. You need to change your Newwork name (SSID), your user name and your password. Change also your wireless security to WEP.
All of this should be in your manual or on line.
The picture below shows the WEP change.
Good Luck
Feb 01, 2010 | Computers & Internet
What caine of oil i need to use to lubricate the chain on my chain saw
they make a specific oil for that: Bar Oil
You should be able to get that anywhere they sell saws/chains
Oct 10, 2009 | Garden
I have a 1996z28 with a transmission problem
.id have to drive the car and see at what position the throttel is whene it doesnt shift.my bet is the either oil and filter change or TP sensor.Check TP sensor.inspect the tranny oil. Feel it,t,smell it. does it smell burnt? is it to milky? does it lack oil? is oil too full. these are some basic procedures in diognosting this sort of problem.
Sep 08, 2008 | 1996 Chevrolet Camaro
Garden Logo
76 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
