Question about Singer Confidence 7463 Computerized Sewing Machine
Needle won't pick up bobbin thread. Has been working fine all week. I changed the needle, took out the bobbin case, cleaned inside but there were no threads or lint. I rethreaded machine and tried a new bobbin. Tried different stitches and different size stitches. Still won't work
    Genius:
  • 1,788 Answers
Most of the time it is because the needle was inserted with the flat side facing you instead of away from you. And for the heck of it, put in a different needle, there may have been a burr or some defect on your new needle. Other than that, it could be your timing.
Posted on Apr 04, 2011
Bobbin not picking up thread
here are some suggestions
make sure the needle is the right one for the fabric being sewed
make sure the needle is all the way up into the needle holder
check to see if the top thread has come off the thread take up lever
try a different bobbin
if the machine is a front or side loading bobbin make sure the bobbin
is inserted correctly into the bobbin case and that the bobbin case
is inserted correctly into the machine
turn the bobbin the opposite way in the bobbin case
also clean under the needle plate and in the bobbin area for lint
it's a possibility that the machine could have a timing problem and
needs to be checked
Dec 10, 2012 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
My bobbin thread won't pick up. Its a new machine and everything came attached. followed the instructions and no go.
Generally, this is because the needle is inserted wrong or because it's bent. In the first case, the top of the needle (called the shank) has a flat side-this has to be inserted so it faces the back or away from you.
In the second case, when a bent needle stops the top thread from picking up the bobbin thread. Even if you think your needle is fine, change it to see if this solves the problem.
May 09, 2011 | Singer 8280 Mechanical Sewing Machine
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
My machine was working.fine when during a seam it froze. I took off the the bobbing cover and saw the bobbin case had shifted out of place. I replaced it and got the needle moving freely again and now my...
clean under the needle plate where the feed dogs are for lint
also get a can of air & use it on the bobbin area
change the needle
rethread the machine top thread & bobbin
make sure the bobbin is not warped or damaged
check the top thread tension
Nov 17, 2010 | Brother CS6000i Computerized Sewing...
Brother CS6000i - Needle breaking, bobbin thread not picking up
There are a few possible causes, firstly make sure you have the correct needle and it is in the correct way and make sure when you fit the needle it is pusshed all the way up into the needle holder. If the shuttle or hook is moving around the bobbin case then the timing may have been knocked out. If the it is not moving it means either the gear or belt that drives the hoo / shuttle has been damaged or broken.
Jun 14, 2009 | Brother CS6000i Computerized Sewing...
Needle not catching bobbin thread
try taking of the pressure plate and reseating it
Jan 07, 2009 | Sewing Machines
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
My needle won't pick up the bobbin thread
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine! roseandjimmy@yahoo.com
Jan 11, 2008 | Brother LS-1217 Mechanical Sewing Machine
Singer Confidence 7463 Computerized Sewing Machine Logo
266 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
