Question about Siemens Dryers
We have a siemens dryer WTXD5321 US/03...when turned on it is making a rubbing noise??? my husband says it sounds like e washing machine. any ideas??
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
  • 221 Answers
SOURCE: Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Posted on Apr 06, 2009
  • 21 Answers
SOURCE: ''Rubbing'' noise in dryer
It souns like your idle pully . It's a small pully that helps ballance you drum.
Posted on Jan 05, 2010
We have 98702. the dryer makes a loud rubbing, or knocking noise. at first listen, it sounds as if there were metal in the dryer rattling around. this is a steady noise. i am interested in fixing myself....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Kenmore 98702 Stacked Washer/Dryer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Jan 05, 2010 | Dryers
Have a constant noise when dryer is running. Best description of the noise sound is, it is a similiar sound like the washing machine is in agitation mode....any ideas what the problem might be??
your felt pads front and rear are worn out these dryers do not use bearings instead they use a strip of felt for the drum to ride on replace these and the noise will go away
Apr 27, 2009 | Kenmore Dryers
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Creda Simplicity Drier
Sounds like the rear bearing has gone
Sep 08, 2017 | Washing Machines
Dryers Logo
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
