Question about Hitachi CMP4121HDU 42 in. Plasma Television
My Hitachi CMP4121HDU plasma monitor has cooling fans that, over time, have become quite loud. Can these be lubricated or replaced?
    Scholar:
  • 67 Answers
The best solution is to replace them. I have tried quieting down fans in the past by lubricating them of just cleaning the dirt off them. About 90 percent of the time this did not work, and if they seize up it will shut down your tv totally. Best thing to do is order new fans for your set. I will try to find manual with the part number for you.
Posted on Apr 03, 2011
  • 635 Answers
Yes they can be lubricated. And is not too complicated, all you have to do is to unplug the TV from the wall power socket and use a + medium size screwdriver.
! ) Remove the back metal cover ( lots of screws ) disconnect the fan cable from the main circuit board. Just make a note of the orientation of the Fan's jack. Or mark both the base of the Circuit Board and the Fan jack with a marker pen so as to know which end goes where.
2) Remove the fan and then notice there is a paper or plastic sticker with the brand name on the back of the Fan motor. Remove this sticker and under that You will see a rubber cap, remove this cap with a pin or pointed knife. As soon as you remove the cap you will see the motor shaft coming out of a copper colored bearing. You have to pour oil onto this shaft, better done if you can rotate the Fan blades from the other side so as to let the oil enter the bearing deeper. You can use a spray called WD40 . Very good lubricant. If you have noting else use light cooking oil !!!
3) Retrace your steps and re assemble the fan. The sticker might not stick back because of all the oil there. The function of the sticker is to keep the rubber cap in place and to prevent dust from entering the bearing.
4) Reconnect the Fan and put back the cover & turn on the TV it should smooth and quite. You will have to do this all over again after a year or so.
Hitachi CML171SXW monitor built in speakers won't work.
internal speakers may be switched off, I/O PCB may be defective, also check the voltage from power supply to audio (I/O PCB) to be sure you have the 12-16VDC necessary, if you have it the power supply OK & most likely the I/O PCB. could also be the speakers themselves(not often both go out together, but possible, can be checked with an ohmmeter) Also be sure to check connecting cables & source..ie. cable or satelite box.
Apr 19, 2014 | Hitachi CMP4121HDU 42 in. Plasma...
Right Door is making loud popping noise
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Cooling Fan is Very Loud
might be a fan with a faulty bearing lubricate it by pulling the sticker off and the cover then use some oil NOT WD40 if this doesnt work then get another fan
Dec 08, 2012 | Compaq Presario CQ56110US Laptop
Does not turn on
Do you hear sound? If not, check the input cable, cable connector etc for possible loose contacts. If these are ok, there is a power supply failure or secondary power failure inside the TV and might require an expert to look in.
Jul 07, 2012 | Hitachi CMP4121HDU 42 in. Plasma...
Can't find an rca audio out on my hitachi hitachi cmp4121hdu. Is there one? or is it just the wired speaker inputs?
Hi I hope this answers your questions today. Your tv does not offer rca audio out, and the built in speakers are the only available that way.
That being said, I suppose you could disconnect the wires from the speakers and feed them out the edge of the cabinet, you would judt have to cut out a spot big enough for the wires to come out.
The TV has an 8 watt stereo amplifier, so I guess as long as you don't expect to be blasting the windows out, you could attach them to external speakers, or even an amplifier, if it allows speaker in, some do.
If you do hook it up to external speakers, just remember that the TV doesn't have a high-watt amplifier, though I suppose you could get an adapter. Speaker levels input and line-level outputs. This would provide you with the rca jacks that you are seeking.
Jan 28, 2011 | Hitachi CMP4121HDU 42 in. Plasma...
The cooling fan is really loud and it has an
you can put lubricant oil on the center where you can found the washer holding the motor.
Apr 03, 2010 | Dell OptiPlex GX280 PC Desktop
Panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Apr 13, 2008 | Panasonic 50 in. Plasma TV
3 Inch block on right side top to bottom.
your best bet is to call hitachi do not mention unit being dropped raise all kind's of hell and hope for the best.
Jun 14, 2006 | Hitachi CMP4121HDU 42 in. Plasma...
Hitachi CMP4121HDU 42 in. Plasma Television Logo
142 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
