Question about Hayward Pool & Spa
Pump runs but there is little to no pressure. somewhat noisey
    Problem Solver:
  • 20 Answers
Is the basket broken or melted ? If so, you may have gotten something inside the impeller causing it to get plugged with debris. There is a special tool to correct this problem. It's made by Pool Tool. It's called an impeller cleaning kit. It's kind of like a long pair of tweezers.
If not, you may have a plugged line. I would call a service pro on that one.
Another possibility is that the impeller may have spun off. An easy way to check is to open the pump pot, fill it with water, then with the lid still off, turn it on for 1 to 2 seconds. If the water got slurped in, you have a good impeller. If not, you may need a new one.
Another possibility is you may have a broken pressure gauge.
Posted on Apr 04, 2011
95 suzuki rf600r and its not running.the fuel pump is noisey but sucking.but it keeps making noise when i release the start button and i feel like its pumping to much fuel could that be the issue?
Check for fuel in the engine oil. The fuel pump should not continue to run until oil pressure light goes out. Check fuel pressure regulator and fuel pump relay(contacts fused closed)
May 24, 2017 | Suzuki Cars & Trucks
When i pull the trigger on my RYOBI POWER WASHER MODEL RY80940 it power or idles down and when i let go of the trigger it idles up i replaced the idle assembly that didnt help what else could it be?
Mine used to do this and it was becauseof the bearing between the engine and the high pressure pump,if the washer was rather noisey then the bearings have gone take the pump off and see if the engine runs ok,if it is the bearings they are cheap to buy off ebay.
hope this is some help.
puggy.
May 31, 2016 | Garden
How do i find out if my fuel pump is going out
A noisey fuel pump can be an indication of a worn pump. You have to do a fuel pressure test to determine if the pump is supplying proper pressure and volume
Apr 11, 2015 | 1998 Lexus ES 300
No gas gettin to engine
. Check for a clogged fuel filter, or if your fuel pump don't run at all, replace the "fuel pump relay". Sometimes your fuel pump will run, but be too weak to hold pressure, which will let your car idle somewhat, but be too weak to run the engine at speed or under load.
Dec 16, 2013 | 2005 Chevrolet Uplander
2005 trailblazer sounds like a jet at startup. It goes away after 15 seconds oe so. can i fix this?
Depends, these trucks had problems with this, the noise you here is the electric air pump, it can be a little noisey, it should sound like a smooth jet engine bad as it starts going bad it gets a little louder but can still last a while (ayear or two), when it goes bad the engine light will come on, if its not too loud a wouldnt worry about it, even a new one will be heard, maybe not as loud but there noisey, it runs on start ups for a few sec -20 -30) hope this helps. good luck.
Nov 07, 2010 | 2005 Chevrolet TrailBlazer
I have agudfos pump for my central heating, I know nothing about it but only two radiaotors are coming on, one upstairs bedroom and the tuitlity room. Any suggestions please? Where should the little lever...
Dependent on the size of system determines which speed the pump should be set. If in doubt set it to 3.
Does sound though as if the system is either air locked (bleed radiators) or system is badly sludged up. Is the boiler noisey or do the radiators that are working have cold spots? If so its probably sludged.
2 options: Buy a chemical cleaner from a diy store or call someone in for a system flush, which will take most of the day.
Oct 30, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Car runs but stalls
if you have to bleed the fuel system, the fuel pump module is defective, its picking up air, possible cracked pickup line in the module, test fuel pressure first, shouild be 48-52 psi, port is on the fuel rail, regardlees eng size. if the pump is noisey, replace... these pumps are nortorious to failure. they come as an assembly. 300.00-400.00 dollars. access in from trunk area,top off hump.under carpet GOOD LUCK, RDJRP
Aug 11, 2009 | 1994 Dodge Intrepid
Discovery 2 noisey fuel pump/lack of power
turn ign on press acc pedal 12 times, management will come on leave untill light goes out .this means the car in self bleed mode
May 12, 2009 | 2002 Land Rover Discovery Series II
Fuel pressure problem
theres 2 options,voltage feeding pump is fluctuating,or pump itself is going bad!
Apr 17, 2009 | 2000 Chevrolet Silverado 1500
Pool & Spa Logo
120 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
