I have a Hitachi HDR325 digital TV recorder. I re-scaned my box as was missing a few channels after the scan the box automatically restarts (usually), but this time it trying to start up but keeps switching back off again it does this a few times and then settle with light on with just the number 0 pressent cannot do anything with it and cannot turn off by stand by button on remote control or the box please help .
SOURCE: UK TV History Freeview Channel
UKTV History now finishes at 18:00, when it is replaced by a new 'cheap-tacky-repeats' channel called 'DAVE'.  Worst thing Free-view has ever done in my mind.
Posted on Oct 17, 2007
jerryg50
  • 1689 Answers
SOURCE: Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Posted on Jun 03, 2008
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
SOURCE: Acer AT3201W LCD TV
I repaired my Acer by replacing the power supply from
http://www.power-on.com/lcd323-4m.html - $85
Acer would not sell me a replacement power supply.
Note: I needed to solder wires the new power supply to the old one,
the pinouts on the connectors on the new one would not fit the original.
Posted on Dec 13, 2008
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Posted on Apr 23, 2009
How do you tune TV
A full retune should only takes a few minutes and can be done with your remote control. Here are some guidelines for how to do it, but bear in mind every model of digital TV or box will be a little bit different.
  • Make sure your Freeview TV or box is on and in digital mode, usually by pressing the DTV or digital button on your remote. Then press 'menu'.
  • Select the 'set up' or 'installation' option. If you see picture icons, select the tool box, satellite dish or spanner. If you are prompted for a code, try 0000 or 1234.
  • Select the full retune option. This is sometimes called 'first time installation', 'factory reset', 'default settings' or 'shipping conditions'. Do not select 'channel update' or 'add channels'.
  • Press 'OK' if your equipment asks if you want to delete all your channels. Don't worry this is normal
  • Channels will automatically be installed. This may take a few minutes and your equipment may shut down and restart
  • In some cases, where transmitter signals overlap, it may be necessary to carry out a manual retune.
Note: Depending on your TV equipment, you may need to update your favourites list following a retune. Some digital recorders may require scheduled recordings to be reset.
Jun 10, 2016 | Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I have a Tevion TDR 5101 DVD recorder which I have had for a few years. I have never managed to get it to work and since I bought it our region has gone over to digital. I have no reason to think anything...
Sadly , it will never work as a digital recorder . they did not make a convertor box for them as they did for televisions when the world had to convert to all digital .
May 04, 2017 | Televison & Video
Since they switched to digital TV, my VCR/DVD player will not record a TV program.
The DR-MV150B has both a digital tuner and analog tuner. Since the digital conversion you more likely have not run a channel scan for the new digital channels. Plugging in a digital tuner would work, but is unnecessary. What you probably have to do is run the 'auto scan' feature through the recorders menu. Hit "Home" button go to the "TV" icon and select "Auto Scan". It will take a few minutes, but recorder will scan for digital channels and memorize them.
Aug 13, 2009 | JVC DR-MV150B DVD Recorder/VCR
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
325 people viewed this question
Top Televison & Video Experts
