Question about Home
Zenith over toilet spacesaver....need t anchor to the wall but cannot find directions
    Genius:
  • 1,739 Answers
Unfortunately the Zenith Products Group do not post their installation information. However you are able to send an inquiry/request to their Customr Service. See here:
http://zenith-products.com/Customer%20Service/Customer%20Service.htm
Posted on Apr 04, 2011
How to install hansgrohe toilet brush
This model has a bracket that will mount to the wall using two screws and plastic anchors. Then the brush holder will snap into place on this bracket. There will be a hole in the bottom of the holder that will look like a set screw but this is only a push pin. It is spring activated and not threaded. To remove it you simply push up on this pin and pull the holer off the wall bracket. If you need further help feel free to contact Hansgrohe Tech at 1-800-334-0455. Press 2 for Tech and Ask for David Scarborough. I'll be happy to help.
Nov 20, 2012 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
How does the YB2808 holder detach from the wall? ......the above answer wasn't an answer....I need to know how to "unsnap" the thing....it IS NOT held on with typical allen screw, how does one...
The anchor is put into the wall in a pilot hole, a mounting post is inserted into the wall anchor, Afterwards the mounting post is pressed firmly until it clicks to stay in the mounting post with the handle down. The locking tab on the mounting post is faced down to fit into the specific area to stay put.
  • If this was over tightened it will be difficult to get off.
  • Try moving the handle from side to side, while pulling the unit off.
  • If all else fails, put tape around the handle, then slide a flat head screw driver under neath, and lift up. the anchor bolt will now want to come out but it can be cut off. Push it back in. Repair the hole and try again if you are moving it anyway.
Dec 10, 2010 | Moen YB2808 Eva Paper Holder - Chrome
How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
The technical specifications and installation instruction for your product are available here.
http://www.moen.ca/shared/pdf/yb2208sp.pdf
At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
Nov 15, 2010 | Moen YB2208CH Brantford Toilet Paper...
Arm has come loose on 2 of 3 paper holders
Here are the installation instructions:
http://www.moen.com/shared/pdf/YB2808sp.pdf
Is it the connection to the wall that is loose?
At the bottom of the post; facing down to the floor; there should be a square hole which will provide access to the locking tab. Use a small screwdriver to release the locking tab to release the post from the mounting post.
To tighten the mountng post to the wall; besides just tightening the screw; you will likely have to replace the wall anchor. After going to this trouble suggest you use a suitable toggle model rather than a plastic plug that be more secure and long-lasting.
After replacing the wall anchor, reassemble.
Trust this is helpful. Please vote. :)
Nov 01, 2010 | Moen YB2808 Eva Paper Holder - Chrome
I installed a Moen Sage toilet paper holder. The right cover that attaches to the wall hardware via a small screw is loose and no amount of tightening corrects the problem. What am I doing wrong?
It is likely that the the mounting post on the wall has pulled loose.
You will need to remove the paper holder and inspect themounting posts; loosen the set screws in the base of the posts to do this.
Try tightening the screws holding the mounting posts to the wall. If the screws are unable to hold tight you will need to replace the wall anchors if they have been used.
Remove the mounting posts and the wall anchors and replace with new wall anchor, preferably a toggle anchor designed for sheetrock if possible.
With the wall anchors in place attach the mounting posts and install the paper holder; tightening the set screws in at the base of the posts.
Installation instructions for your product can be found here:
Oct 18, 2010 | Moen Home
What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Installation
If you are going into drywall then a threaded drywall anchor like this
Will be best.
Yopu can buy them at any hardware store. They screw right into the drywall and then another typical screw goes through the mounting plate into this anchor.
I recoment getting metal anchors as the plastic ones break easily.
These hold MUCH better than the push in plastic anchors.
Dec 30, 2008 | American Standard 6723S 'The Standard...
How to Install Toilet Paper Holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
Aug 27, 2008 | Hansgrohe E & S Accessories 40526000...
Home Logo
53 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
