Question about Maytag Washing Machines
Timer on washing machine runs through it's cycle but the drive motor never runs. It fills with water but will not agitate or spin. Does not seem to want to drain either. This is a Maytag LAT9700AAW top load washer. I think the timer is bad, but am not sure. Is this a typical failure?
  • Maytag Master
  • 3,361 Answers
The lid switch or the lid switch fuse may be bad.
Open the control console to check the switch and fuse located in the center of the machine,behind the control panel.
Also check the belts underneath to make sure they are not broken or stretched.
Posted on Apr 03, 2011
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Kenmore 90 series doesn't spin out all the water
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Kenmore 22422 Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
That is probably a problem with the timer.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Oct 11, 2008 | Bosch Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    67 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
