Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
I have a Maytag stackable washer dryer Model LS7806. The washer will not fill. Where is the fuse that controls the water inlet valve?
  • ex-mechanic Apr 30, 2011
    Hi Kevin,
    Sorry it took me so long to get back to you. I think you may have identified the problem. I have a question:
    I am looking at a plate (part#28 on the diagram you sent). There are two square rubber pieces (part #6). Do I need to peel those off to get the plate off and get at the switch? Also: What tool would you use to get the tiny hex-head bolts out?
    Thanks for your help.
    Eric Johnson
  • ex-mechanic May 01, 2011
    A screwdriver won't work -- There are no slots in the hex-head bolts. They look like 1mm or 2mm heads -- I don't have a socket that small and was hoping the specs will tell me what sized socket I need to buy....or that there's some other tool I don't know about.
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please check this picture....part#11 is the water level switch that controls the water level through the valve. Please get back to me if you have any other questions.
Kevin
Posted on Apr 03, 2011
  • Kevin White
    Kevin White Apr 30, 2011
    a screwdriver and yes you can peel that off :)
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
I JUST INSTALLED A MAYTAG STACKABLE WASHER AND DRYER AND WHEN I TURNED THE WATER SUPPLY ON THE WATER STARTED TO FILL UP IN THE WASHER IMMEDIATLY AND IT WONT STOP UNTIL I TURN OFF THE WATER SUPPLY TO THE...
Unplug the washer, if the issue continues, you have a faulty inlet water valve. What happens is particulate matter gets in and the valve jambs. If you have a new unit, the repair should be for free.
The only case where I could see water going in, is if it was requested, by user input....But front loaders use tons less water......
Feb 12, 2011 | Maytag LSE7806A Top Load Stacked...
I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
I have a stackable Maytag. The water will not
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
When washer fills it does not stop unless done manually
HI, i recommend testing the timer/control device for faults. make sure it is spinning and not shorted. if the timer/control device is in good condition, this will confirm a serious fault in the water valve assembly(inlet). replace this device in this case.
May 22, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
318 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
