Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Soap dispenser doesn't open - KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
  • KitchenAid Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Apr 03, 2011
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser doesn't open during wash cycle
heatman101
Jul 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The soap door does not open during the wash cycle
Hi
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
The soap compartment will not open during the wash cycle.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap dispenser door will not open during operation
Hi
Hope this helps... Please revert for any further assistance.
Daniel
Aug 26, 2010 | KitchenAid Dishwashers
Does not release soap from despencer
Hi
Daniel
Aug 21, 2010 | Dishwashers
Water is coming up through the kitchen sink when dishwasher is running and teh soap depenser will not release the soap.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these. Please do rate this solution and revert for further assistance.
Daniel
Aug 14, 2010 | Maytag Dishwashers
Soap dispenser won't open during operation
Hi
Daniel
Aug 02, 2010 | Maytag Dishwashers
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
112 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
