Question about Black & Decker 18", 6.5a Electric Mower
The side discharge chute cover on my B&D electric LM175 lawn mower has broken off and the side bag will not stay on. What do I need to repair this so the side bag will stay on?
SOURCE: Saw your post about Black and Decker MM525 Lawn Mower
With the Black and deckers, I think you just take the blade off and turn it over. That wil direct the grass clippings down into the ground.
Posted on May 10, 2008
  • 313 Answers
SOURCE: cannot find a replacement bag
product no longer available
Posted on May 29, 2008
  • 313 Answers
SOURCE: I need a Discharge Chute
discharge chute part # 243524-00. visit www.toolpartsdirect.com
Posted on Jun 27, 2008
ccrozier_agr
  • 36 Answers
SOURCE: broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Posted on Nov 29, 2008
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
How to replace grass deflector
I have provided a link on how to change the discharge chute on a walk behind lawn mower. It is usually pretty straightforward across manufacturers so it should be of help to you.
But in quick terms, you lift the chute cover that holds it in place, remove your current deflector, and insert a new one! It's easy!
Best of luck!
How to Replace the Discharge Chute on Toro Walk Behind Lawn Mower
Jul 14, 2015 | Poulan Pro PR550N22SH 22Inch Briggs ...
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
This item is discontinued by the manufacturer. Is there another bag I could use with my black and decker LM175?
if the manufacture doesn't have or recommend a replacement, either buy another lawn mower or get a really good mulching blade... a gator blade or similar
Oct 19, 2014 | Black & Decker Ba - 075 Side Bag Assembly
Need manuel for Worx Lawn mower
Sears Direct has manuals. Sorry, all I can find.
Sep 04, 2013 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
Torro Lawn Mower side discharge spring
There are 2 bolts with nuts that mount the spring/door assembly to the mower deck.
Jul 08, 2013 | Garden
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Sep 21, 2010 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
Switch connection
position the switch terminal facing you & the black round lever facing up postion.now all left side terminal are for red & white.
next step all right side terminal are for 2 black wire. doesn't matter the red & white are top or buttom as long as its in the left side only.
Aug 25, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 18", 6.5a Electric Mower Logo
112 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
