Question about Dryers
Everything works but the drum do not spin - Dryers
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 03, 2011
When the machine is on spin it has left the contents around the drum and they are titley clamped to the drum an take some effort to release them it has happened four times
The centrifugal force of the spin forces everything in the drum to the outer most limit, that is how the spin dry part of the wash works,by forcing the water out of the clothing through the holes in the drum,but if it bothers you, you can either add a bit more washing or reduce the spin speed of the machine
Feb 09, 2017 | Washing Machines
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
My indesit 6105 does not finish with a final spin but everything else works and the drum spins up to this point. This means that the clothes come out very wet
There is fault on the final spin as it fails to dry or drain off the water from the clothes. It is possible that the RPM for the spin is not adequate or the timing is short. Please choose a different program to confirm. Also check for free movement of the drum or else use a de-greaser to the drum spindle bearing assembly.
Aug 02, 2013 | Washing Machines
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum won't spin
The most likely cause is a broken belt. Of course there are other possibilities, but start with the most likely. If you hear the motor running and if it's blowing air out the exhaust vent, then you probably need a new drive belt to spin the drum.
Nov 28, 2008 | Dryers
Kenmore dryer drum want spin but everything else works what is the problem
Most likely the long belt is broken (around the drum). If you lift the top (it may need to be pried open - but check for screws first) ...you should see the problem.
Apr 21, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
