Question about Iomega 34579 1 TB USB 20 Hard Drive
It is making a stange noise and does not work anymore , what s wrong and can it be fixed??
    Problem Solver:
  • 10 Answers
In most cases irregular sounds comming from HDD(Hard disk drive) mean reading failure. Clicking noise usually means that disk head is having trouble reading data, it could be just a small fraction of info lost if it's only a few sectors, but if the drive is unrecognized after plugging it in and clicks all the time it's most likely a complete HDD head fault. Data recovery of such faulty drive is expensive and requires special tools and knowledge.
Posted on Apr 03, 2011
Hey just got an Atari of eBay and it works bit there a Stange popping noise and the picture jumps a bit and colors change. If you have any idea how I can fix this let me know. Thanx
Well the noise might be the ac adapter thats causing the problem then and clean the gamepacks out with qutips and rubbing alcohal. Always buy consoles from reptuable sellers because the stuff will generally work better.
May 07, 2012 | Atari 2600 Console
2002 mercury mountaineer had a grinding noise when i backed up and turned the wheel to the right, I took it to the ford dealer and they said my transfer case, tie rod on one side and my brakes and bearings...
I would take it back and tell them you just spent 3k and they didn't fix it. And you dont feel it should cost you anymore for them to fix it. If it is making a noise how can they say there is nothing wrong? Could be as simple as a brake backing plate rubbing the brake rotor. It may have got bent slightly when they replaced the bearings and other parts.
Jul 09, 2017 | 2002 Mercury Mountaineer
My mic continues to make a buzzing noise. I just bought it and barely used it. It was working perfectly and then it started doing it. It works sometimes but not anymore. when I hold it in my hand it...
this problem need to be fixed, your microphone need to unlock it, and see if there is any piece in a wrong position, try to isolate each piece, without cutting any wires, it seems like a hard process but its not that hard, and remember you should do this unless you are sure that there is no shallow problem like the wire that is plugged onto the computer, see if its appropriately inserted id not do the process yourself.
Mar 30, 2011 | Samson C01U Consumer Microphone
Stange noise from unit? i-pod when docked red light just flashes
power supply board, if you have not already sent it back, pleace contact point of sale or b and w service. they should fix it.
Dec 11, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Just had my 2000 Beetle in for a general tune up - nothing wrong - and now the coolant light is beeping and flashing red. Is it safe to drive it back to the mechanic?
All VW engines need to have the cooling system bled of all air after refilling.its safe as long as you dont hear any stange noises and you carry a bottle of water after youve checked its full.
Oct 07, 2010 | 2000 Volkswagen Beetle
1993 Nissan 300zx non turbo: my car makes a stange growling noise when it's cold. once it warms up it goes away. I'm guessing it's an exhaust problem. What is making that noise and how do I fix it?
could realy be any thing , im assuming it probley goes away in 5 minutes. remeber your car is a 1993. lots of old parts metal and plastic if its running okay and its not realy a problem its just an old car i would sugest checking the entire exaust system especialy the hangers
Jul 26, 2010 | 1993 Nissan 300ZX
Machine drum will not turn at all, fills with water and emptys. No stange noises though
What make machine do you have as many are similar fault but differ in soloution
Feb 06, 2010 | Washing Machines
Kitchenaide microwave not heating - no stange noised, everying else seems to be working just no heat
there are few sensors inside that might go bad but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 27, 2009 | KitchenAid KCMS185J Microwave Oven
Psp slim dosent read umds dono whats wrong makes a little noise
it might be that your lens that reads the psp is dirty so it cant read them
May 28, 2009 | Sony PlayStation Portable (PSP) Console
Bad Rod?
you can fix it. you shouldn't drive the car anymore to prevent damaging other parts. it sounds like a spun bearing, which is cause when the bearing doesn't recieve enough oil. the bearings are usually in a fixed position with the crankshaft rotating between them. the knocking noise is from the bearing wearing down from lack of oil, and they start rotating with the crank.
it might not be worth fixing because the cost of fixing it may be more than what the car is worth.
Oct 13, 2008 | 1999 Pontiac Grand Am GT
Iomega 34579 1 TB USB 20 Hard Drive Logo
252 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
