Question about Dell DIMENSION 3000 CELERON 2.4GHZ CD-RW,80GB,256MB WINDOWS XP DESKTOP PC (074576101317)
Carresearch, I just put the cd in and restarted the computer but the reinstallation didn't start. How do I reboot the cd first?
  • artlutherie Apr 03, 2011
    I have the boot sequence list. There's 4 items on the list but I can't figure out how to change the sequence.
    I just figured it out. I've got cd first, hard disk for 2, IBA on 3 and diskette drive on 4
    Does this sound OK? And should I only check mark cd and hard disk c: ?
    Sergeant:
    Champion:
  • 209 Answers
OK, Here's what you need to do. Shut down the computer. When you restart it, as it boots, continue to press and release the F2 key as the computer starts up. When it does, you will get a BIOS setup screen. From there, there will be an option to change boot sequence. Make CD drive first and then C: drive. Save your changes and then reboot. This time, the computer should load your reinstall disk. Let me know how it goes.
Posted on Apr 03, 2011
  • 2 more comments
  • Julie Endres Apr 03, 2011
    You have to use your arrow keys and the enter key when you're in the BIOS. You highlight what you want to get to by using the arrow keys and select by hitting enter. There is usually a menu at the very bottom of the screen that tells you what keys will do what. Try that. It's hard without looking at it but if you're still having trouble let me know and I'll go into my bios and see what the actual keys are to do it.
    I have no problem highlighting and unchecking items but I can't change the order.
    If I un check all but the cd rom will it do what we want it to do?
    OK, on mine if I use the arrow keys to highlight the CD rom drive, F5 moves it up in priority, and F6 moves it down. I found this out by looking at the box at the very bottom of the screen that tells what each key does. Let me know if it works. If not, I'll look for info on the Dell website. I didn't have any checkboxes on mine.
    I'm not sure if my reply went through so I'll try again.
    I have cd set on 1 and drive c: set for 2. Should I check mark IBA and diskette drive?
  • 23 Answers
You have to change the boot order by going into "Setup" (BIOS) and changing it so that the CD ROM drive is before the Hard Disk Drive in the boot order. Usually it's pretty easy to find in Dell (Pheonix) BIOS..
Something they have started doing in PCs built in the last 7 or 8 years is put a recovery partition on the Hard Disk itself. It can reatore the PC to factory settings in about 20 minutes (sure beats the 2+ hours it typically takes)
follow the directions here:
http://en.community.dell.com/support-forums/software-os/f/3524/p/19267286/19460157.aspx#19460157
Can not load nero 9 or any other nero,,been told its the dvd burner reads dvd put blank dvd in burner fails every time
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Oct 16, 2011 | Computers & Internet
How can i reboot my computer
  • Reboot means Restart
  • maybe you mean format & reinstall? Requires the CD or probably a boot disk
Dec 14, 2010 | Computers & Internet
I Need to reboot and i dont know how to
There are two ways. the best way is to click "start" then select "restart" (same as reboot).
this is a soft reboot because you never really power down the computer. You can also hold the power button in for a few seconds and it will turn the computer off. if it doesn't restart by itself momentarily press the power button once more.
Jun 26, 2010 | Computers & Internet
My dell computer won't reboot. How do I reboot it from a cd?
If you are running Windows XP, open the DVD tray (if you could), then load the Win XP installer.
Restart the computer, and it will tell you to press any key if you would like to boot from CD.
Just hit any key and your computer should reboot using the CD.
Thank you and good luck!
Apr 26, 2010 | Dell XPS 200 PC Desktop
I am having trouble reinstalling the operating system. THe message " remove disks or other media. Press any key to restart." There is nothing in the cd drive or floppy drive. I just want to do a fresh...
Insert the genuine Microsoft CD-ROM disk into the CD/DVD reader. Press any key to reboot the computer, reading from the disk, to start the reinstall.
Mar 26, 2010 | Compaq Presario 1200 Notebook
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
CD's won't burn right!
Try reinstalling the drivers for your CD bay.
Either the CD that came with the bay, or find them online ....
Right-Clickie your My Computer and find the name of your CD Bay in the list on the Hardware page ... delete it, or right-clickie and uninstall the driver.
Reboot the computer and it should re-detect the drive, or find the drivers you copied earlier.
If that doesn't solve the problem, then it might be the type of CDs that you are using. Have you changed brands lately??
Jun 12, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Hello,l'm trying to formate my daewoo pc.l press Delete to inter setup,however, it is on safe mode.l want to start the setup from the CD.Thing that l'm finding it hard now.so, please,can you help me find...
REBOOT..GO INTO THE BIOS AND MAKE YOUR CD/DVD FIRST BOOT RESTART.COMPUTER WILL BOOT FROM CD.FOLLOW THE PROMPTS AND FORMAT AND REINSTALL..THEN ACTIVATE.RICHARDM69
Dec 03, 2008 | Computers & Internet
Compaq c310 laptop to be booted
To boot from the disc, you need to restart your computer. As soon you see the HP logo screen keep on tapping F12. You should select the option CD/DVD drive or CD drive. Make it sure that your XP cd is inserted.
Please be reminded that if you will reinstall your windows XP everything will be wiped out from your computer, your documents, picture and any other documents.
You may follow up the instruction using the link below.
http://tinyurl.com/gac7w
Keep me posted.
Thanks.
Oct 17, 2008 | Compaq Presario Notebook
Computer rebooting
go to start, control panel, system, hardware, device manager, then click the drive thats doing tis under disk drives or cd dvd, repair the drive, if that doesnt work uninstall it then reinstall it, or reinstall it from the last point it worked. let me know
Sep 19, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Dell DIMENSION 3000 CELERON 2.4GHZ CD-RW,80GB,256MB WINDOWS XP DESKTOP PC (074576101317) Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
