Question about Canon PIXMA MP510 All-In-One InkJet Printer
Canon pixma mp510-when switch on -grinding sound - then error 5C00 message - when open cover - ink assembly unit does NOT move to center - please advise
  • 310 Answers
The purge unit is blocked,the purge unit is on the rigth if you open the scanner.You must unzip the printer to look at the purge unit.In the main part you need to replace the purge unit.If i have been useful please give me a vote :).Thanks
Posted on Apr 03, 2011
Cannon MP510 shows error 5C00 switch it on and ink containers do not move.
they might not be all the way inplace sometimes they have to click into place, check that they are in the little "tracks" or lines they slide into
Feb 09, 2013 | Canon PIXMA MP510 All-In-One InkJet...
I have a Pixma MP510 with error code 5C00. When I lift (Open) the printer the ink tanks do not return to centre for inspection. It has occured for first time to day. Switched the printer on and off and...
That's a jammed purge unit issue (search for 5C00 or purge in that link.) That is, the degunker got gunky!
"purge sensor error which means that something is jammed or broken in the purge unit. Most of the time all it is are the wiper blades that clean the bottom of the printhead get stuck in the extended forward position. Gently press on them and see it they will release. Press down on the two ink pads and they should move down at least 1/4" with very little force.
Other than this, you may have to take the printer apart and examine the purge gear very close. It could also be just a jammed piece of paper. I have had people find all kind of things dropped in there, such as paper clips, staples, cigarette butts, etc."
--trigger1937
Jul 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Cure needed for Canon MP510 Printer for code 5C00
Hello and Welcome to FixYa!
The 5C00 error is a defective signal from the Purge unit. This error code is telling you that the purge unit did not complete a good power on cycle and the cam is not in the correct position. Typically this means the purge unit is stuck extended due to accumulation of a lot of dried up ink.
Open the cover and when the head comes to the center, pull the power cord. Once that power is off you can now move the carriage to the far left so it is out of the way. Now use a paper towel and gently blot all the excess ink off of the ink Pads and press them down. If the Wiper blade is extended, clean it and it should snap back in position. If it is still stuck, try sparying the area with Windex but don't get any on anything except the pads.
This D.I.Y thingy may seems a bit out of the scope, Yes I'll recommend you to get your printer service in case.
I hope you will have a clear picture now. Concerned, Nooh.
Jun 08, 2011 | Canon PIXMA MP510 All-In-One InkJet...
My printer has come up with a service error 5c00. What can i do to fix it?
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Mar 21, 2011 | Canon PIXMA iP90v Printer
I am getting an error message that says 5C00
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
Jan 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5C00 on Mp 500 please help with fix
Dec 01, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error 5C00 canon 4700
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. Open the cover and when the head comes to the center, pull the power cord. Once that power is off you can now move the carriage to the far left so it is out of the way. Now use a paper towel and gently blot all the excess ink off of the ink Pads and press them down. If the Wiper blade is extended, clean it and it should snap back in position. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Nov 26, 2010 | Canon PIXMA MP510 All-In-One InkJet...
What problem of erro 5C00 ?
Nov 25, 2010 | Canon PIXMA iP3500 Printer
Printer makes loud noises while powering on, and displays error code 5C00
Nov 23, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Error 5c00
check in inside the fusing unit by the roller.
May 12, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
481 people viewed this question
old marine
old marine
