Question about Olympus IS-500 35mm SLR Camera
I have not used my IS-5000 SLR Olympus camera for about 5 years and Now when I changed the batteries and turned it on the lens does not react as usual and the film also could not reload!
  • 185 Answers
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Posted on Dec 14, 2008
SOURCE: Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Posted on Jan 24, 2009
  • 919 Answers
SOURCE: I need a users manual for an Olympus om-G
http://www.butkus.org/chinon/olympus/olympus_om_g/olympus_om_g.htm
This is a link to a website that has a copy of the user manual for the camera.
Posted on Mar 16, 2009
cpt100
  • 154 Answers
SOURCE: film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Posted on Apr 01, 2009
  • 102366 Answers
SOURCE: I'm looking to buy a
Yes, as long as it's not a DX lens. DX lenses are designed for the smaller image area of some digital cameras and will cause vignetting (dark corners) on a 35mm camera. The vibration reduction feature of VR lenses won't work, but won't cause any problems.
DX lenses will fit and work, but as mentioned above, you will get dark corners.
Posted on Nov 15, 2010
Testimonial: "Thanks!!"
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
The camera is stuck in the open position but will not operate. The battery is new. it shows a charge, but the shutter will not go, nor will the film advance.
Are you using the lens that came with the camera? If not do you have an original Olympus lens you can put on it and try? Some of the adapters/aftermarket lenses on the market are/were considerably less than awesome, some would even partially obstruct the mirror's movement. Others just had shotty firmware or components and would require more voltage to operate then the body could produce. If its not lens related, pull the battery and check the contacts in the door and at the bottom of the battery bay and make sure they aren't a)twisted/damaged, or b) too far depressed for the battery to make solid contact. After so many battery changes the contacts can get pressed too far down for the contacts to connect. Fixing it can be a bear and honestly, knowing if they are too far depressed can be just about as difficult. Not sure if this will help but its a place to start. Best of luck!
Jun 29, 2011 | Olympus IS200 SLR ZOOM SINGLE REFLEX...
I'm getting an ERROR 99 message when I turn my Canon SLR on. I've tried changing the battery, cleaning the lens and powering the camera off and on but I'm still receiving the same error. Any solutions?
see to it there's no jam on parts mechanism inside, it need to reset to authorized service center or find reset button on the unit but not all slr have it outside some are located inside some dont have it
Feb 12, 2011 | Canon EOS 5000 35mm Film Camera
I want to use my OM2000 Olympus lens for my video Canon XL1, do you know Olympus has built any lens adaptor to Canon XL? Reap
Olympus did not make adapter for OM lenses to be used on Canon XL1 but, if you are looking for the lens adapter, Novoflex XL-OM Lens Mount Adapter Olympus Lens to Canon XL-1, is the lens adapter that suppose to work.
B & H has this adapter for sale.
Jun 23, 2010 | Olympus OM-2000 35mm SLR Camera
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
Olympus E-300 Digital SLR storing black images.
Most likely the shutter "curtain" (a few pieces looking like sheet metal just behind the mirror, designed to protect the camera CCD from dust and damage due to too much light) is not opening. This will require servicing by Olympus, since you will have to take the camera apart to be able to reach this camera part. Unfortunately, this may be a pretty expensive repair.
Apr 18, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Apr 06, 2009 | Olympus FE-330 Digital Camera
How to use a manual zoom lens with Evolt 510
By manual zoom lens I am assuming you mean a film camera lens. If it is one of our OM 1 or 2 lenses they can be used on our Olympus digital SLR camera but you will need to purchase an MF-OM1 converter to be able to adapt those lenses to fit on our digital SLR camera. Then you will only be able to shoot using those lens in manual focus mode. Auto focus mode will not be available.
Sep 25, 2008 | Olympus Cameras
Minolta 5000 doesnt open aperture
The camera keeps the lens open if you look at the back of the lens you will see a small lever if you push it it will open the iris and let go it spring back if that ok it the camera that faulty
Jun 05, 2008 | Minolta Maxxum 5000 35mm SLR Camera
Using the lens
As long as the lens mount is compatible with the Olympus e410, you can use this lens.
It will only be limited by what features are supported through the camera body - I suspect that you will have to do everything manually.
Good luck.
May 10, 2008 | Samyang 500mm f8 Ultra Telephoto Manual...
Olympus IS-500 35mm SLR Camera Logo
55 people viewed this question
Top Olympus Photography Experts
mbutkus
Level 1 Expert
Bart Pulverman
Are you an Olympus Photography Expert? Answer questions, earn points and help others
