Question about Cameras
I want to know how many pictures i can take with 2GB picture card
    Master:
    Sergeant:
  • 398 Answers
This will depend upon what megapixel rating your camera is, and what quality setting you keep on it. Here is an example, I have a 7.1 megapixel camera and I use the best quality setting, and I get 919 pictures on my 2GB card.
Posted on Aug 05, 2008
When i put sdhc card the frame is not working
The problem is that your Digital Picture Frame is only compatible with SD cards, not SDHC cards. You bought a larger card for your Digital Picture Frame, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the Digital Picture Frame is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 04, 2011 | Matsunichi PhotoBlitz PF7E Digital...
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
My computer will not pull up pictures off my 2gb sandisk sd card.
Hi! Maybe what you're talking about is the 'Autoplay' feature of the computer. Autoplay can be disabled at some times so you cannot see it, or Autoplay only displays a view picture 'icon' when there is/are picture/s on your 2gb sandisk sd card.
To manually view your pictures, you can follow this steps:
1. Head on to your computer by clicking Computer on the Start Menu.
2. From there you can see an sd card icon that displays your inserted 2gb sandisk sd card name.
3. Click that icon, then from there you can see and browse the files on your 2gb sandisk sd card, including your pictures.
Click Helpful if this fix your problem :) It would be a pleasure.
Further questions? Comment below! It will be entertained. :)
Aug 18, 2017 | SanDisk 2GB microSD Memory Card
How do it work, my 2gb flash memory, trying to down load my picture on it
When the card is inserted the computer assigns it a drive letter. You will find it in my computer. Once you know what drive it is you can simply right click on a picture or folder right click and use sent to to send it to that drive.
Dec 04, 2009 | PNY 2GB microSD Memory Card
If card indicates "Format Card" will I lose the pictures I took?
Memory cards are not made to hold pictures permanently. Like any stored data, they can be glitched and then you've lost the data. You should always copy them to the computer hard drive AND make a backup or 2. Even CDs can go bad. All my pictures are stored at least 2 but sometimes 3 places. Perhaps there is a way to retrieve the data, but I do not know how. Contact the manufacturer and see it they can help... but I'm afraid you've lost them.
Oct 14, 2009 | Lexar Professional High-Speed 2GB Secure...
My SD 2gb card just became unreadable
Hmmm try running Undelete on it. There are free versions, here is a link to one: http://majorgeeks.com/downloadget.php?id=4407&file=1&evp=3346a8401ada2b5e3bc1fb27693170be
Install that, then run it on memory card, I have recovered thousands of pictures for people using this method.
Hope this helps
Sep 24, 2009 | SanDisk 2GB microSD Memory Card
Cruzer micro 2GB - "Directory or file cannot be created"
In all likelihood, your SD card is formatted FAT and you are hitting the limit on number of objects in the root directory. Check the format type and if it is FAT, I would recommend reformatting as FAT 32 which has more lenient restrictions.
ALTERNATIVE: If you really do not want to reformat the card, you might try to remove a few pics to free up space in teh directory and then create a subfolder to store picture in. Object in this subfolder should not be counted at the root.
Aug 12, 2009 | SanDisk 2GB microSD Memory Card
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
