Duet whirpool washing machine stop and DLF sign appear
  • 668 Answers
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Posted on Apr 03, 2011
Whirpool Duet Washing machine F-11 error
I purchased a Whirpool duel washing machine Aug 05. In June of 08 it showed an F11 error. After factory repair service tech. looked at it he said that i needed a main motor at a cost of $400.00 After search on internet many people reported problems also and decided not to repair it. Has any one had problems with theirs?Ihave the same problem is there any solution????please help
Jan 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reset the 'Conrol Lock' on a Whirpool Duet Washer?
press and hold the end of cycle signal button for 3-5 seconds
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Washing machine prob
You need to replace the door interlock. Try giving the handle a firm push and see if the machine will start.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
200 people viewed this question
Top Washing Machines Experts
