Question about Garden
It says not to touch it can I install it using a towel ?
  • 43,501 Answers
Yes anything to keep your finger oils from getting on it...
heatman101
Posted on Apr 03, 2011
My third brake light keeps blowing out on my 95 Buick lesabre how do I fix this problem
Are you touching the bulb with your fingers when you install it? The oil on your skin will cause the glass to break or crack and will cause the bulb to fail, in short use rubbing alcohol to clean it and don't touch it with bare skin use a paper towel. Also is water leaking into the light fixture? I had this issue and I installed an LED bulb replacement and no more problems.
Mar 18, 2017 | 1995 Buick LeSabre
I keep replacing the head lights only to have them burn out again.
make sure you dont touch the bulb with your bare fingers. touching them will make them burn out within days or weeks. use something clean, a napkin, paper towel, or similar. avoid touching the bulbs.
Jan 18, 2011 | 1989 Ford Tempo
My printer won't print black. ink is full, other colors print. Printer tests say everything o.k.
I would like to share with you my personal experience with printer issues. I have canon i455 printer which has black & blue color clogged. Here is the solution:
1. Buy Ethyl-alcohol/ethanol solution (70% or more). You can purchase this at any drug stores. Isopropyl alcohol may work as well.
2. Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol liquid into paper towel layer (use more layer/thick to avoid ink from being drop into table).
3. put the printer head on the top of wet towel - with the face of HEAD touching the towel.
4. rub the head to the towel until you get rid of built-up ink on the head.
5. Pour some alcohol liquid into the printer head container (ink-receptacle area where the ink cartridge normally sits (there should be a little hole down in there where the ink actually flows from the cartridge into the head). Be careful do not touch the electronic parts. Let's dry overnight.
6. repeat step 2-5 if necessary.
7. Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, repeat until no more dead nozzle shown.
good luck!
Dec 10, 2010 | Canon I960 InkJet Photo Printer
How to change headlight bulb on 1998 es300
open your hood look behind the headlight you will see various cables depending on high or low beams are the cables you need to fallow the projector beam is low beam and the hallogen is high beam look for the clip that holds it in place do not touch new bulb with fingers this will damage the bulb use a paper towel or such to install nothing is to touch bulb or the life of the bulb will be shortened by residue left on it
Apr 01, 2010 | 1998 Lexus ES 300
HP C4280 hasn't worked for months now and hardly been used - message comes up saying ink cartridge is empty when it isn't. I'm not an expert but a couple of experts have looked at it and various things...
Remove the ink cartridge.
Place it, bottom-down, on a wet paper-towel.
How much ink is "pulled" from the ink-cartridge.
Move to a different spot on the paper-towel,
and touch it again.
If you see "less" ink, or none at all, then it is an EMPTY cartridge. Refill it, or replace it.
Jan 14, 2010 | HP Photosmart C4280 Aio Printer
Hi, i have marshmallow smeared on my car seat and i havent touched it as i would like to know the right way of cleaning it.could you please help me. robyn
i know how to fix it!!! all you need is a pair of tongs boiling water a towel and a possitive attitude! just boil the towel PLEASE USE THE TONGS to put the really hot towel on the seat over the fluff let it sit for a sec to let it warm up. then just scrub it off with said towel. :3
Jul 14, 2009 | Baby Gear
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
MY TOWELS ALL COME OUT HARD AND ROUGH
no, the tumble dryer has nothing to do with it. My family always complain about our hard towels. Recently our front loader broke down & I had to hire a top loader til it was fixed - my towels became luxiously soft after just a few washes in it! I think it is how much more the washing is spun out. I am going to try to reduce the front loader spin speed when I get mine back. I never use a dryer on towels - takes too long.
Oct 29, 2007 | Candy AQ130 Front Load Washer
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
