Question about MSI 770G45 Motherboard
I have a msi 770-g45 motherboard, my computer suddenly just died. Now it wont power up anymore. The led indicators give a short blink and nothing more happens.
  • MSI Master
  • 5,660 Answers
Usually a direct indication of a bad Power Supply. Weak voltage power rail, (Or more than one)
1) ALL of the LED lights on at once would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Depends on what Processor it is.
You have enough power to briefly light a few LED lights, and that's it.
Do you have a KNOWN to be good, Compatible power supply available to use for a test unit?
One you could perhaps borrow from a working computer?
[Note*
Failed power supply, and computer is dirty inside, are the two leading causes of computer failure.
The Power Supply is cooled by air as are the components inside the computer.
The Power Supply uses Heatsinks inside, and an internal fan, for it's cooling components.
Example of the inside of a typical SMPS, (Switched-Mode Power Supply),
http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
The cylindrical blue 'can' shown as B, is an Electrolytic Capacitor, (Radial Aluminum Electrolytic Capacitor)
To the immediate right of the blue capacitor is a Heatsink. Looks like a series of finned squares connected together.
There is another Heatsink to the right of the letter C.
{Basic construction of a Heatsink is a plate of metal with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, and the tall, thin fins absorb heat from the plate.
The fins then radiate the heat away.
The fan draws air across the fins of the Heatsink, and the air flow helps to carry heat away}
When the fins of the Heatsink are clogged with dust, dirt, etc., and the Fan blades, center hub, and surrounding cage, {Shroud}, are also clogged, the cooling capacity drops tremendously.
This causes the components inside the Power Supply to overheat.
Heat = Wasted Energy
The Power Supply strains to keep up with the call for power, but due to the overheated condition cannot, and eventually components inside the Power Supply fail.
Opening a Power Supply, and trying to repair it is not a recommended suggestion.
Electrolytic Capacitors can hold a charge for weeks, months, sometimes over a year.
Without using the proper technique to drain the residual power from the capacitor/s, the charge can be released to YOU.
The shock can be Bad to Fatal ]
Best suggestion is to just replace the Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette.
Posted on Apr 03, 2011
Z77A-G45 wont start no bip
check your power supply make sure all power plugs are in all places
Sep 05, 2013 | MSI Motherboard Z77a-g45 Core
Help! Computer is not starting on power on. Fans spin momentarily
SOUNDS LIKE MOTHERBOARD IS FRIED, OR FAULTY POWER SUPLY
Apr 14, 2013 | Computers & Internet
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
Aug 31, 2012 | MSI Hp Compaq Evo Ms-6541 Rev 1.0...
Msi 870-g45 failing to POST?
hi, i had a similar issue some time ago, dependng on your hardware i would suggest you look into a psu tester, or swap it out for a friend's psu, i assume you've ripped everything apart and put it back together to see if some dust was shorting somewhere, is it related to heat maybe, expansion of cracking can sometimes occur in computers that have gotten hot in the past, especially in the circuitry behind the cpu.
Good luck
Nik
Jun 04, 2012 | MSI 870G45 AM3 AMD 770 ATX AMD Motherboard
Getting 3 beeps on my MSI 870-G45 motherborad
If they're happening during POST (After the bios screen loads but before the OS boots), it could mean a memory error. Also, it can depend on the length. If they're three short beeps, it's the memory. Long and short combinations mean different things as well. You can find a good description of different beep codes in the source.
You can verify a memory error using memtest86+. It's a burnable ISO you can easily find on google. Turn it on and let it go and it will let you know if any tests fail. If they do, it could just be one of your cards. Try taking one of the cards out and turning the computer on to see if it still beeps. If it does, switch cards. Also try putting them in different slots. Usually the combination of switching cards/slots will let you know if it's a bad card, or a bad slot.
Source: http://ec.transcendusa.com/helpdetail.asp?Help_No=70 - beep codes
Everything else is experience :)
May 28, 2011 | MSI 870G45 AM3 AMD 770 ATX AMD Motherboard
I have a lcd monitor citizen tv set LT2010 , suddenly it doesnt work anymore and there is a blinking red light, i unplugged and nothing work.. please help me
Monitor power supply board have dead components parts call capactiors most likely.The power supply board that the board where the power a/c cord plug into it.U have all the tools and know basic electronic also can do basic soldering works?Yes,take it aparts and check the power supply board carefully and replaced all the dying or dead capacitors components capacitors parts,these dying capacitors parts dying are alway bulges and puffing up onto it tops.Replacing all the dying and dead capacitors that are having bulges or puffing up onto it tops,monitor will have red power light indicator LED light stable again and will stop blinking.The monitor will work again.
May 11, 2011 | Televison & Video
All LED lights up but nothing comes out of the monitor and the LED for HDD is not blinking.
Make sure if you have a 4 pin 12 volt connector on the board, it is making connection to the supply.
Try disconnecting the power to motherboard from supply and disconnect your CMOS battery.
Short the clear CMOS connections to assure memory drain.
Remove and reseat your CPU and Memory.
Re-install all remove and try the unit.
Nov 25, 2009 | MSI K8NGM-V Motherboard
MSI K9N6GM MotherBoard Install
you could have a faulty power supply, or something in the motherboard settings could be set to switch the pc off after so many minutes/hours. or you may have a faulty connection which short-circuits in the motherboard or somewhere in the pc, casuing the pc to switch off as a safety feature. this is NOT what it actually is, this is a SUGGESTION.
Nov 28, 2007 | Computers & Internet
MSI 770G45 Motherboard Logo
222 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
