Question about Thermador KBUDT4255E 42" Side-by-Side Refrigerator with External Ice Dispenser - Masterpiece Handles
Hi, this morning when I woke up, I saw a pool of water under my Thermador refrigerator. I think that is water but I am not 100% sure. This refrigerator is only <1 year new. Is this water leaking or coolant leaking?
  • Thermador Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
Gd5sha water under the freezer
This normally occurs when you have a large buildup of ice in the freezer, when it does a defrost there is just too much water for the hat on the compressor to handle. Make sure the door to the freezer & fridge is closing properly & the seal is in good condition & not falling off, moisture in the air causes frost in a freezer. So too many door openings can cause the same problem.
Nov 20, 2013 | Whirlpool Refrigerators
I have a Whirlpool refrigerator 21TFA that may have a drain problem or a clog. It drains in the evening, but this morning when I woke up, it smelled bad from the bottom of the refrigerator. Any advice?
Hi and Welcome to FixYa I am Kelly,
A bad smell from under the refrigerator is a result of either a dead rodent or.. dirt and lint accumulation in the plastic drip pan / catch basin and then the defrost cycle water wets it 2 to 3 times a day intensifying the smell.
Unplug the unit
Remove the rear fiberboard cover that covers the compressor area
Use a shop vac and rags to clean out the drip pan / catch basin. (These can be VERY foul if they have never been cleaned!) Make sure to clean the condenser coils and condenser fan area also. Inspect for varmits / rodents (deceased) with a flashlight. You can wash the drip pan using a rag with vinegar and water then soap and water.
Lastly... make sure the END of the drain tube that terminates in the drip pan is clean. If there was lint build up that caused a muck pool in your drip pan the muck often clogs the end of the drain line.
You never know what your going to find under a refrigerator! I could expound but it is not pleasant and only you will be able to discover the secrets of your refrigerators' "underside life." All I will say is.. it is always a... revealing experience.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
Water collecting below veggie compartments water inside
Take you bastor and find the drain hole and blow air into the line to open it up. The drain from inside to the pan is clogged.
Jun 11, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water leaking from ice maker GE model# TFH22PRS
Hi
Please check to make sure the water tubes are attached properly and are fastened tightly.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 16, 2009 | GE Refrigerators
Samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Thermador KBUDT4255E 42" Side-by-Side Refrigerator with External Ice Dispenser - Masterpiece Handles Logo
218 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
