Question about Hasbro Nerf N-Strike Raider Rapid Fire CS-35 Dart Blaster - Blue
I took my CS-35 apart to paint it a different color and I mixed up some springs and I am unsure of where a piece goes. I know the general area, just not how to put it in place. Could I get a Diagram of the inside of this dart gun please?
  • 3 Answers
Found a video YouTube about steps to putting back the CS-35. Good Luck
http://www.youtube.com/watch?v=lgrfmkXoQqQ part 1
http://www.youtube.com/watch?v=DlJ2xrLrKBw part 2
Posted on May 23, 2011
Whats the primary color of blue?
Please first study on color wheel to get the thorough knowledge. Then furthermore, you can read some books and play some DVDs for art lessons to get some more sound knowledge to be equipped with yourself. Check out: Art instruction books DVDs and everything you need to learn to create any...
Feb 02, 2015 | Crafts & Hobbies
What color of spring goes on what side in rear brakes
The springs are painted for appearance only. the hold down springs are the same and then primary and secondary springs some are different sizes, match them up as you remove them. the color is not for location only appearance. good day
Jun 24, 2012 | 1992 Buick Roadmaster
On a brother cs 8060 - as i pushed the thread compartment into the machine a silver metal forked thing flew off the machne hitting me in the neck. it has two pins one on each side and is actioned by a...
the piece that flew out goes to the piece that lowers with the wire. mine is having same issue but i saw mine right before it flew off. not quite sure how it goes back together.
Jan 07, 2011 | Brother CS-8060 Computerized Sewing...
Why do rear brake springs have different colors
two reasons for difference. Often springs are coded by color because they have different spring rates or wire diameters. Second reason is so they are more easily identified as to what goes where during assembly.. (Generally the case on brake springs)
Nov 18, 2009 | 1997 Jeep Cherokee Country
I have some chips on a Findlay cookstoves enamel.It is old and the enamel is light green.Any ideas where I may find something to touch it up?
There are several brand of touch-up enamel paint for appliances. Krylon for example, it's carried by a wide variety of retailers such as Home Depot, K-Mart, Sears and Walmart.
You can also get it at store that specialize in paint like Sherwin Williams. They might also be able to give you the best match to your color. If not you can try appliance stores. They may be able to give you a good match. The only other option is to match it yourself. The best way to to that is to get some color card examples from a paint store or hardware like Home Depot and find the best match. Now get a list of the colors that they use to mix it. Ask if you can get a very small amount of the colors used in the mix and using trial and error mix it yourself.
You can also try mixing it to get your color using enamel auto touch-up paint.
There really is no source for old appliance touch-up paint so it will never be perfect but with a little trial and error you can get pretty close.
Hope this helps you out.
Prep before painting:
  • Sand the damaged area lightly with fine-grit sandpaper. Roughen the area to be painted and remove any rust, but avoid sanding the surrounding surface.
  • Clean the area thoroughly with a rag dampened with paint thinner. Let dry.
  • Paint over scratches with appliance touch-up paint, using the bottle's applicator brush or another fine-tip paintbrush. Let dry overnight.
There will be issues with areas that are exposed to high heat so be prepared to repeat when necessary.
Nov 13, 2009 | Stoves Kitchen Ranges
Mitsubishi Cs-35707 Tube
I am sorry,in my other response I had this tv mixed with a rear projection tv,the response still applies because one of the transistor in the standing metal plates being held by escrew is the green output transistor and I can see it has 3 of them(one for each color)Look up the number on its face and replace it with an exact replacement or replace all 3 at the same time,it will not cost much.Let Us know how it goes.
Oct 12, 2006 | Mitsubishi CS-35707 35" TV
Hasbro Nerf N-Strike Raider Rapid Fire CS-35 Dart Blaster - Blue Logo
1,636 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
