Question about Canon PIXMA iP4200 InkJet Photo Printer
Printer makes rapid, sharp snaping sounds just before and sometimes after printing.
  • 23 Answers
It's a sign of a dying printer. My guess is that it is a plastic gear skipping or missing teeth. I've had several inkjet printers with this issue, but how long it will continue to work after hearing this can't be gauged.I had one printer that lasted almost 2 years after it began to "snap"... Another printer died in just a few weeks. What will end up happening is the printer will most likely throw an error up, and that's when it's toast. If it were a more expensive printer, it might be worth fixing, but this model can be purchased for less than $80.
There's a reason those printers are only $60 - $80. For your next printer, I suggest reading a LOT of online user reviews, especially if you are going to go cheap. There's nothing wrong with going cheap, but you have to be even more careful. When I buy printers, I even read the reviews for the ink cartridges it takes, just to see how long they really last.
Posted on Apr 03, 2011
Solution for system error [H4-00]
Low heater error, try # * C * on keyboard in rapid sequence to put copier in service mode, enter number 14 and hit print key all sharps are almost the same sometimes if you are low on toner the machine will run too long and do this but the problem, is in the fuser. 35 years Sharp experience,
Jul 01, 2014 | Sharp AR-5316 Advanced Digital Imager...
Will not print from Acer laptop
Is the copier locked, do you need to input a user code to use the copier?
If so, you need to enter that user number in the job handling tab of the printer preferences page.
Jan 28, 2014 | SHARP MX-3100N
I have a SATO M-8400RV printer that stopped printing. When powered on, it make a rapid ticking sound, the display is flickering and the stepper motor does not move although it apears to be receiving at...
Sounds like the power supply/motor drive board is bad. You might consider a new printer or repair the power supply. The printer is obsolete and only a few parts are currently available from Sato
Nov 04, 2010 | SATO M8400RVe Label Printer
SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Jun 17, 2009 | Sharp AL-1540CS All-In-One Laser Printer
MX-2300N Sharp Copier will not print
Do you have setup accounts on the copier?
Feb 11, 2009 | Sharp MX-2300N Color Copier
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Mp 750 printer makes a noise like rapid hammering for about 5 seconds-than a message check printer
It sounds like the track gear may have a broken tooth. However, try removing the print cartidges and then reinstalling them. Make sure they are completely reseated.
Please let me know how it works out for you.
Nov 28, 2008 | Cannon Office Equipment & Supplies
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
Printer works when it wants to.
apply a spray of contact cleaner on print switch while you move it many times-open the machine check printer connecter is fixed firmly to board -put some light grease in gears.check if something droped in paper path and remove it.
Nov 23, 2007 | Sharp EL-1197P Calculator
Printing problems
Make sure that the collate button is not turned on as this sometimes has the result of this fault.
Thanks J
Jul 03, 2007 | Sharp AR-C260M All-In-One Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
old marine
old marine
