Question about Walgreens Health & Beauty
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
  • Anonymous Mar 21, 2014
    normal blood pressure of this age
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 102 Answers
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Posted on Sep 19, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Hello, 1 Place the stethoscope ear pieces around your neck and wrap the cuff of your sphygmomanometer tightly around your upper arm. Lay the blood pressure meter of the sphygmomanometer up on the table in front of you, so that a pressure reading can be easily seen.
2 Locate the pulse of your brachial artery by tracing your finger down your bicep down toward the crook, or inside elbow, of your arm. You should find the brachial pulse about an inch or so above this crook.
3 Put the ear pieces of the stethoscope into your ears and place the the round, metal end of the stethoscope over the pulse of your brachial artery. Tuck part of the stethoscope end underneath the end of the sphygmomanometer cuff that's bordering the inside of your elbow. This will keep the stethoscope end in place while you pump the sphygmomanometer.
4 Tighten the stopcock on the sphygmomanometer bulb and squeeze the bulb of your sphygmomanometer multiple times to inflate the cuff around your upper arm. The cuff should be inflated until you've reached 180 mm of pressure. You will be able to determine how much pressure you've pumped into the sphygmomanometer cuff by reading the blood-pressure meter in front of you.
5 Release the bulb stopcock slowly and gradually. This will let the air out of the cuff, allowing you to make a blood pressure reading.
6 Note the number on the meter when you first hear your pulse through the stethoscope. Then note the number when the last pulse sound comes through the stethoscope. Record these two numbers by placing the higher number over the lower number to determine your current blood pressure
Courtesy: ehow
Posted on Apr 03, 2011
  • drgirish Apr 03, 2011
    120/80 is the NORMAL value a little above it or below it is considered normal.
    90/60 is considered borderline low
    140/90 is considered borderline high
    Dont rely on your readings if you are not trained to measure your blood pressure. Get yourself checked by a trained professional!
    New Friend:
  • 11 Answers
Blood pressure readings
sphygmomanometer...
Time to buy yourself a good blood pressure cuff...
Because a properly trained person is going to read
systolic over dyhistolic... nothing else will do.
Carnac the Magnificent
Mar 10, 2017 | Miscellaneous
The needle on the Sphygmomanometer gauge will not return to its zero reading. Otherwise it seems to function correctly.
This will happen sometimes, if the BP Cuff has been dropped and the gauge gets stuck. Have you tried tapping on the gauge with your finger, to get it to return to 0 ? Also. be sure the thumb screw air valve is fully open and the cuff is completely deflated. The gauge is easily replaceable, if necessary. Just contact the manufacturer of your BP Cuff or if you prefer Sphygmomanometer.
Thanks for choosing FixYa.
Sep 22, 2011 | Lifesource Aneroid Professional...
"Lumiscope"Sphygmomanometer needle begins on 80 mm/Hg and will not go any lower.How do I get it to go back to "o" ?
to let the needle go back to zero, find the air valve of the sphygmanometer then turn it counter clockwise or clockwise, depends on your sphygmanometer manufacturer.
Aug 11, 2010 | Lumiscope Aneroid Blood Pressure...
The needle is stuck on 120 on my sphygmomanometer
This problem may need to be escalated to a higher repair center a place like a precision measurement equipment lab. With it being a gauge I wouldnt recommend opening or doing anything to it since it is used to measure blood pressure.
Mar 10, 2010 | Palm Aneroid Sphygmomanometer By Mdf...
Have lost instructions for Marshll 85 Oscillometric Sphygmomanometer Electronic Digital Blood Pressure and Pulse Monitor...... is this available? #'s on box are 705203 and M 453952
I suggest you contact Omron with your requests for Marshall 80-series blood pressure monitors. Omron seem to have bought / acquired / become otherwise responsible for the Marshall brand.
That is how I got the manual for model 80 here
Owners Manual User Guide for Marshall Professional Aneroid Sphygmomanometer...
To request a manual from them send a message to them with your exct and detailed request using the webpage
Contact OMRON OMRON Global
I hope this helps
24.February.2015
Jul 10, 2009 | Marshall Health & Beauty
DIFFERENT READINGS
i would say try durecell or energizer batteries first because some models work better with name brand batteries and if that doesnt work then there may be something wrong with the machine and should you have to purchase another one do not buy that brand try omiron, theyre pretty good, i have a talking one which i brought from avon. good luck!
Jan 26, 2009 | Mabis 04-795-001 Talking Wrist Blood...
Blood pressure Question
Measuring your own blood pressure is an important way of monitoring your health. High blood pressure is a major health problem, which can be treated effectively once detected. Measuring your blood pressure between doctor visits on a regular basis in the comfort of your home, and keeping a record of the measurements, will help you to monitor any significant changes in your blood pressure. You should also keep an accurate record of your blood pressure, to help your doctor diagnose and possibly prevent any health problems in the future.
Aug 27, 2008 | American Diagnostic Corporation 700...
Health & Beauty Logo
815 people viewed this question
Top Walgreens Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Jamie Sewell
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
