Question about Asrock P4I45GV P4/845GV/FSB533/A&V&L/Modem/MATX Motherboard (MOTASR20)
After cleaning my cpu fan(above processor),whenever i start my pc , display not comes while monitor led are blinking
  • 13 Answers
After cleaning the cooling fan , you have to put thermal paste on the processor , then it will work
Posted on Apr 05, 2011
  • Asrock Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 04, 2011
My HP monitor, connected to CPU does not display anything on the screen but the power is on, showing yellow and green colour (blinking).
first remove the cover switch of the computer and check the cable from the monitor to the computer is connected properly then check wethe the smps is working then check wether the processor fan is working if working remove the meomery card and clean with a clean cloth and also remove the processor heat sink and clean both surface of the heatsink and the processor and lay a thin layer of heat sink solvet and replace the processor fan firmly to the processor and switch on the computer
Mar 26, 2011 | Computers & Internet
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
Using a V2 PREMIER winXP my vga monitor will not display says" anlog signal" Do I need your monitor ? to display or can a get avga to work
I'm using an HP 2009m LCD monitor. (TFT, and 20 inch widescreen) No, you cannot have my monitor higgie2, lol!
FixYa is a product support website. FixYa provides solutions to problems with the Viscom V2 Premier computers, but is not directly associated with Viscom.
[ When a computer sends out video signal information, it is in the form of digital. When using a VGA monitor you are using an Analog monitor. The computer has to convert the digital video data, (video Information), into Analog ]
Pull up a chair, and grab a cup of coffee, or a pop. This is going to be long. Warning you in advance.
When No Analog Signal is displayed on the monitor it means the same thing as No Signal.
No video signal.
The monitor is working correctly, it just isn't getting a video signal from the computer.
Could be due to;
A) The monitor cable is bad
B) The computer isn't working
Computer isn't working usually due to a bad Power Supply. Weak voltage power rail.
LED lights will light, and fans may spin, but the Processor isn't turning on.
Not enough power.
(This is why it can seem as though the computer is working, but in reality it Isn't)
1) ALL of the LED lights on at one time use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Depends on what Processor it is.
The Viscom V2 Premier desktop computer uses an ECS P4VMM2 version 8.1 motherboard.
(ECS = Elitegroup Computer Systems)
The ECS P4VMM2 motherboard supports Intel processors that use the Socket 478 processor socket, and have a Front Side Bus of either 400MegaHertz, or 533MHz. (Front Side Bus = FSB)
Can use Intel Celeron processors, or the better Intel Pentium 4, or Celeron D.
(With the above FSB specifications)
http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Click on the Specifications tab
The Intel processors the ECS P4MM2 v8.1 supports are listed in CPU Support.
Click on the CPU tab.
The Intel Celeron and Celeron D processors that meet the above criteria, and are supported, can use up to 73 Watts.
http://en.wikipedia.org/wiki/List_of_intel_celeron_microprocessors#.22Willamette-128.22_.28180_nm.29
(Scroll the page down also to view all of the supported matching processors)
The Intel Pentium 4 the ECS P4MM2 v8.1 supports can use up to 89 Watts.
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Willamette_.28180.C2.A0nm.29
Point of all of the above?
To show you what processors are supported, and the Maximum Wattage they can use.
Again, this is why you may see LED lights lit, and fans spinning, but No Analog Signal on your monitor.
NO processor operating.
No processor operating, no computer.
No computer operating, No video signal to the monitor.
Solution is to replace the Power Supply.
(Also use a can of compressed air for computers to clean the inside of the computer out)
I would also advise removing the Ram Memory module/s ('Sticks'), and cleaning the gold plated contact pins on the bottom, with a pencil eraser. use air to remove the eraser dust.
(You can use air from a can of air if available, or air pressure from your mouth will be sufficient)
Remember, BEFORE working on the computer,
1) Computer on a table
2) Computer unplugged from power
3) Observe Anti-Static Precautions
For further questions, or if you need advice in replacing the Power Supply, or guidance in choosing one, please post in a Comment.
Regards,
joecoolvette
Nov 23, 2010 | Viscom V2 Premier 17'' LCD Computer...
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Power light keeps blinking but the screen never comes on
it is just the indication that the PC is in standby mode! if this is the case in restarting the system u can see that the red LED of the CPU which should blink when the system is on will not blink! that means that the processor is not coming on. u can just open the CPU and unplug the smps and clean the pins of it mainly the ATX pin and reconnect it, it should work then. if still it is that same then try some other working smps! reply and revert back if it still persist, don't forget to vote please!
Jul 06, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
No any display & sound then i power on my PC my pc is intel 815t abit st6, red led is always on but no display? can any one help me??????
First check your num lock key led if it on and off when you press num lock then your cpu gives diaply to monitor perfact.
Then check your display connection from monitor to cpu.
When you power up the computer pressF8 ket then enter in enable vga mode.Then go to control panel -> display->property ->settings.
Then change screen resolution to 1024*768 then apply and ok .
But if you still not get dispaly then
-> Open cpu cabinet.
-> Refix RAM meory clean all dust from motherbord chip set .
-> pull cmos cell for 15 minutes.
-> Reattch ATX power supply to motherbord.
-> Refix processor it is bottom of processor fan.
Please rate my solution if it help you .
Thanks for using fixya.
Jul 20, 2009 | Computers & Internet
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
The power on my pc keeps recycling
remove all hardware except RAM n CPU and then try it if the system gives you a disply then add all hardware 1 by 1 and keep checkin this way you can find the problem with the harware compatibility if the system wont disply then check the mobo for RAMs and CPU respectively if the problem presists then you have the BAD BOARD.-
Jan 16, 2008 | Intel D845GLLY Motherboard
Asrock P4I45GV P4/845GV/FSB533/A&V&L/Modem/MATX Motherboard (MOTASR20) Logo
94 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
