Question about Vitek Home Security
Where can i find a schmatic on the Vitek VT-E8 DVR. Recently at our church after a severe lighting storm it wiped out a camera. Camera was replaced but the DVR (model mentioned above) channel for that camera was also knocked out. I would like to secure a schmatic for the DVR so that I won't have to ship it out and be without our security system
SparkGap
  • 363 Answers
SOURCE: samsung b/w ssc 12c home security camera system
New fittings (terminations) should be available from your local electronics store. They would require crimping onto the cable or soldering although I have seen a variety that screws on.
Posted on Oct 02, 2007
cbinny1
  • 64 Answers
SOURCE: Vertical lines on security camera
Sounds like a monitor that is on its way out....I would do a quick test and swap that monitor out with a different one and see it the vertical lines come back.....Let me know if this helps.....
cbinny1
Posted on Oct 29, 2008
  • 7 Answers
SOURCE: I have a Samsung SSC-Dual
If the harddrive dosent boot up the unit wont come on.try reseating the harddrive in the caddy drawr.
Posted on Apr 03, 2009
  • 7 Answers
SOURCE: I forgot my password and I cannot do anything.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Posted on Jul 09, 2009
SOURCE: I need to find the user manual for a Homeland
If you provide an email I can send you scanned copies of the manual pages.
Posted on Aug 22, 2009
Need manual in english hd portable dvr with 2.5"
Hi Cynthia: Not sure what brand name your camera is, but I found this using a simple google search. The picture is the same, but as you must be aware there are several manufacturers along with numerous brands...Hope this helps....Best.....James
Oct 14, 2013 | Mostbuying Portable HD Car Camera DVR with...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
'card protected' vivitar DVR 925 hd ive already unlocked the sd card and it still reads card protected?
I recommend you move the switch on the SD card back and forth several times. Occasionally, they do not make good contact, and this will hopefully wipe any impurities off the connections.
If this does not help, try a different SD card. Fortunately, they are not too expensive these days, and you can often find sales for a 4 gigabyte card for $10 or less.
If that doesn't help, the problem is in the camera. If it is no longer under warranty, you may have to get it professionally repaired. Depending on how much you paid for the camera, it may not be worth it, however. Be sure to get an estimate of the repair cost before agreeing to have it done.
Jul 14, 2011 | Vivitar ViviCam 8025 Digital Camera
My camera worked very recently, as I took pictures on a camping trip. However, a few days later after getting back, I've found that it refuses to turn on. If I turn it to either Video or Photo, the light...
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare CX6200 Digital Camera
My camera won't turn on.
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 21, 2009 | Samsung SL202 Digital Camera
Fuji finepix s1000 zoom error lens is stuck out what can I do???
If you recently dropped the camera, you may have damaged the lens housing -- that will require professional repair. Otherwise, your problem may be as simple as low batteries or corrosion on the battery terminals inside the camera. Make sure that the batteries are fresh/fully charged. If the problem persists, remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and replace them in the camera. This cleaning works about 90% of the time, and I hope it clears up your problem.
Sep 10, 2009 | Fuji FinePix S1000FD Digital Camera
Storm ravaged old film camera- no power
Water or any liquid is a camera killer, unless it's a under water camera. don't know of any camera repair shops that will repair liquid damaged camera's Reason---- cannot guarantee them. So it looks like you have a neat paper weight.
Oct 13, 2008 | Photography
Bought a replacement remote that doesnt work......
first lets do a checking at your remote to make sure its working properly, how ? use a digital camera and point it where the LED or eye of the remote , when pointing the camera to the remote press any button of remote while watching the camera , if you see lights coming out its means remote is working .I did some searching myself at the website you purchased the remote, look like thet send you the wrong replacement. the right replacement model is MODEL: CLU436UI , not VT-RM6654a . hope this helps .
Apr 24, 2008 | Hitachi VTF392A VCR
I lost my adapter to recharge my camera
You might be able to buy a replacement or universal adapter at your local CircuitCity or Best Buy. If you can find one there, may I suggest that you contact the camera's manufacturer.
Mar 24, 2008 | Vivitar DVR-390H Digital Camera
Dark Images
Recently this happened to me just as I was walking in a church to shoot a wedding (major bummer). I had to rush and get my film backup for this. Anyway, this problem has ocurred with several examples of the S2 pro including mine, one other than mine that I know personally. The problem is the sensor. I quickly shipped to Fuji and they fixed the problem. I just got my camera back and so far it is working fine. Time will tell. I had to pay for the shipping only and turnaround was quick (1 week). By the way the camera was already out of warranty, but they gave a 3 month warranty after the repair.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Home Security Logo
54 people viewed this question
Top Vitek Home Security Experts
Lawrence Oravetz
Are you a Vitek Home Security Expert? Answer questions, earn points and help others
