Question about Western Digital WD SiliconEdge Blue SSC-D0128SC-2100 2.5' 128GB SATA II MLC Internal () SATA II Solid State Drive (SSD)
After installing a wd siliconedge blue ssd in my system the drive was formatted and now shows up in my drives list in windows, but when i try to do anything with it i get an error that says 'disk is write protected'
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Apr 04, 2011
How do I remove dual boot screen in bios startup after Cloning my WD Hard drive to a Samsung SSD
go to run type "msconfig" and go to "boot" tab then there list of Operating Systems is displayed, Choose the OS you want to remove and then press Delete
Jun 11, 2014 | Computers & Internet
My SSD (ata ts256gssd720) is not recognized when I try to install win7, I had ubuntu earlier (only ubuntu from the beginning)
When you say "not recognized", do you mean that the drive does not show up under "My Computer" with a drive letter? Or that the OS does not even know the drive is there? It is possible that the SSD was formatted using an Ubuntu-specific file system that Windows does not recogize. In this case, the drive may be seen as "Not Activated". To check this in WIN 7, click on START, then right-click on COMPUTER and select MANAGE. When the Computer Management window appears, under STORAGE, select DISK MANAGEMENT. Wait for the window to populate, then scroll down looking for the SSD in the list. It should list a disk number, size, and status of the drive. If it is not ONLINE, then there is a problem. You will probably have to initialize it, partition it, and format it to have WIN 7 see it. Be advised however, that this will remove all data previously stored on it.
Oct 30, 2013 | Transcend Computers & Internet
I have a gigabyte motherboard ga-z77x-ud3h, a new system install a samsung SSD with the OS loaded to it Windows 7 (64bit) ultimate and a 2TB hard drive that is not displayed in windows, however both drives...
Hello here is the homepage for the mainboard:
http://www.gigabyte.com/products/product-page.aspx?pid=4153#dl
If you choosed to install windows in ahci mode, you have to make this setting again in order to boot correctly from the drive.
Is the 2 tb hd visible in the bios ?
If so you have to format the drive in the windows system when running, in order to use the drive.
A format of a drive can also be done when installing windows.
If the hd drive is brand new its not formated.
A youtube video will show you how you do this:
http://www.youtube.com/watch?v=wzXoqZTxl_Q
Remember also to use the ahci setting first for this drive
in the bios ( if available )
Remember also to format the drive in NTFS file system.
Also remember a format will erase ALL files on the hd drive.
Good luck
Sep 15, 2013 | Gigabyte Computers & Internet
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
Ssd won't show up as destination drive.
I'm not sure this is your problem, as you question isn't descriptive enough. But here's a solution if I do understand your question correctly.
When I have installed new hard drives in the past, I did the physical install, turned the computer on, and they just worked. Not so with SSDs I've installed. After the physical install, the SSD does not show up in the "Computer" window with all the other drives; because it's not FORMATTED.
Solution:
Navigate through:
Start > right-click on "Computer" in the right pane > select "Manage" > in the left pane select "Disk Management"
All the drives will show up in the main window, including the SSD you just installed. If it does not show up, there's a problem. Maybe one of the cables isn't fully inserted, or there's a defective cable, or a defective SSD.
You can tell the SSD from the other drives by the Gigabyte capacity, and also by the fact that it does not have an assigned drive letter (e.g. C:). Also, it's named something like "New Edition".
To continue to formatting, navigate:
Right click the SSD > select "Format" > select "Quick Format"
A drive letter will be assigned. You are given the option to change this letter if you want. Also, you are given the option to name this drive. This name will appear with the drive listing in the "Computer" window. I simply used the name "SSD", however if you want something more discriptive or colorful, it's your computer, it's your SSD, you can name whatever you want.
The other format option is for when one is installing a used HD which may have bad sectors. That option scans for bad sectors, and takes a LOT longer to format. Not necessary for a new SSD. Plus, you can scan a drive for bad sectors anytime with the "chkdsk" command.
The SSD is now ready for use, including for use as the main drive. Windows will happily load onto this drive.
Nov 10, 2012 | Samsung 830-series Mz-7pc128n/am 128gb 2.5...
I got a HP DV6833us. Originally has a WD scorpio blue drive (don't remember which model) and running Vista (OEM). the hard drive is dying. I want to replace it with WD2500BEVT from Best Buy. On WD...
Note: If you cannot find drivers for your WD drive, it may be because most WD drives do not include drivers as they use a standard driver built into the OS. If the driver is built into the OS or is already installed and the OS continues to look for a driver, your drive has most likely failed or been damaged and needs to be replaced.
According to Western Digital: "Most current WD drives do not require additional drivers on the Windows or Mac OSX Operating System (OS) beyond the ones that are included with the OS."
In order to simplify the installation process WD elected to use the standard drivers that are built into common operating systems. While there are a few exceptions to this, in general, there are no drivers provided by WD for our drives. That's because the drivers a WD hard drive or SSD uses are part of your Operating System. As such, any trouble with these drivers should be handled by the regular line of support for your operating system - in most cases by contacting your system manufacturer, IT department, or the publisher of your OS.
Internal Hard Drives and SSD: All internal Hard Drives and SSDs use drivers that are built into the operating system. There are no drivers available for download because of this. If your internal drive is not recognized, it can be caused by one of the following problems:
  1. During an operating system installation, it may not see your drive at all or may request a driver. Under Windows you will need to press F6 in order to be prompted to enter a driver. Once you are prompted for a driver you will need to remove your Windows CD, and place a CD with the drivers for your SATA or EIDE controller card. These can be obtained from your System Manufacturer (Dell, HP, Toshiba, Gateway, etc.) your motherboard manufacturer, SATA or EIDE card manufacturer (if it is connected to a PCI or PCIe slot). Western Digital cannot assist you in locating these drivers, as every controller card requires a different driver.
  2. Your driver may be corrupted. The symptoms of this problem can vary - if it is your boot disk, your operating system may fail to load. If it is a secondary drive it may request a driver. You will need to contact Microsoft or your System Manufacturer for assistance in resolving this issue.
  3. Your drive may be damaged or have failed. A good test for this is to try the drive in another system. If the issue continues to occur, then this is most likely the case.
Sep 16, 2011 | Western Digital WD Scorpio Blue WD2500BEVT...
I attempted to install this in my computer using a SATA to IDE converter cable. Dos picks up the harddive, but windows doesn't seem to show it anywhere. I attempted to use the WD format program, but it...
  1. When you install a hard drive, it must be activated, partitioned, and formatted. Open your Start Menu, then open the Control Panel.
  2. Open the Administrative Tools control panel.
  3. Open Computer Management.
  4. Select Storage > Disk Management.
  5. Find your new drive, right click on the drive and partition and format your drive to see it in Explorer.
Aug 05, 2011 | Western Digital WD Scorpio WD3200BEVT hard...
My western digital hard drive comes and spins but it will not show up on any computers?
f your WD external drive is not recognized, it can be caused by one of the following problems:
  1. Your driver may be corrupted. The symptoms of this problem can vary - The majority of the time however, the drive may request a driver, or will not appear as a connected device. You will need to contact Microsoft or your System Manufacturer for assistance in resolving this issue, as we are unable to provide assistance in diagnosing your OS.
  2. Important Information: It has been reported to us that some users have been able to resolve this issue using the SFC Command in a Command Prompt. When contacting Microsoft or your System Manufactuer, providing them with this information may assist in resolving this issue. Please note that WD Technical Support cannot assist with the usage of this command line program, and is not responsible for any damage to your system or data it may cause.
  3. Your drive may be damaged or have failed. A good test for this is to try the drive in another system. If the issue continues to occur, than this is most likely the case. For assistance replacing your drive under warranty see Answer ID 8: How can I replace a product under warranty?.
  4. In some cases you may need to install a drive in order for your drive to be recognized. Check the table below to see if your model drive requires a driver to be installed besides the one that is included in your Operating System. Please note that this table includes any drive that has a driver for any reason.In most cases the drivers listed are not required for the drive to function, but add some additional funcationality that the OS supplied driver cannot provide. If an OS is not listed in either column, your WD external drive is not supported on that OS. If a driver is available, select the OS in the list to go to the download page for that driver.
Select the type of drive you would like to find a driver for:
Dec 04, 2010 | Western Digital My Book Essential Edition...
Device not working/screen shows installation driver problem
You can try to format the disk NTFS File system.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format NTFS files system.
hope this help you
Regards
uttam
Dec 27, 2009 | Western Digital Elements powered by WD 320...
Pendrive not work
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jan 30, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Western Digital WD SiliconEdge Blue SSC-D0128SC-2100 2.5' 128GB SATA II MLC Internal () SATA II Solid State Drive (SSD) Logo
83 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
