Question about Peg Perego John Deere Gator HPX Ride on Toy
My son gator will not work in 1st gear and 2nd gear ony the right wheel turn and it will not do nothing in reverse can you please let me know what might be wrong with his gator. Thanks
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You have a bad motor you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 12, 2012
4 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I have a John Deere
From your description the problem is a motor problem. You should turn the wheel manually and is it can rotate freely, if not then the motor is stuck and you can check the ball bearing if it is rusty or dirty or both and this can make it hard to rotate and that is why it become warm.
Posted on Nov 13, 2010
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
SOURCE: will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Posted on Jul 10, 2009
Only 1 wheel turns in 2nd nothing in 1st or reverse
you have a bad motor, whichever side isn't turning you need to replace that motor
Jun 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
My sons gator first quit working in Reverse, then it stopped working in 1st gear. And now in 2nd gear only one wheel is working. Please help. Also, if I order the necessary part, do you include...
you got a bad motor, disconnect the wires to the motor of the wheel that isn't turning and see if it works then, then let me know if you need me to order you a motor
Jun 09, 2011 | Peg Perego John Deere Gator HPX Ride on...
How do you engage 2nd gear. only works in reverse and 1st gear.
is the limiting screw still in the gearbox? just remove it and it should shift right into 2nd gear.
good luck!
Jan 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
!st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
Goes in 1st and Reverse but not 2nd
Something you may want to check is to see if there is a "governor" for the 2nd gear. My 4 year old has a 4x4 similiar to this and the only two gears that worked were 1st & reverse until my husband had to unscrew a piece from the 2nd gear setting..check the manual or if you don't have one, look online through the manufacturers website. I hope this helps!
Feb 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
No 1st or Reverse, but will go in 2nd
I just bought one for kids for christmas. Out of the box the switch was already installed. Only worked in 2nd gear. I pulled switch and it only hooks up one direction. Under dump bed theres a cover that lifts up and 2 wires goin to each wheel. The wires to the right wheel were unhooked. As soon as i hooked them up 1st and reverse started working. Dont know if this is the case for yours but worth a try.
Feb 15, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
136 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
