Question about Bosch 24 in. SHV55M03GB Built-In Dishwasher
Removing decor door
I need to remove the decor door from a defunct dishwasher but don't have the instruction manual
    Novelist:
  • 116 Answers
With the door open all of the way you should see a series or torx 20 (small star shaped round head) screws around the perimeter of the inner stainless steel door panel. The outer door is usually held on by the topmost 2 screws on the outer corners and 1 on either side of the door in the second position up from the bottom of the door. There may also be a catch under the panel which will require the door to be slid upwards a little.
Be careful when the panel releases as there is about 15 to 20 pounds of spring pressure and the door may want to snap shut.
There may also be a small plastic cap on either side of the door panel about 8 inches from the top. Under these caps is a screw which clamps the door panel down. It will have to be loosened or removed if there.
There is no danger in removing all of the torx screws from the inner panel if the door still will not release.
This is for the standard installation but bear in mind that not everyone follows the instructions when installing the panels...
I
Posted on Aug 05, 2008
SOURCE:
I have a Bosch Exxcel larder fridge and wish to reverse the door, can you help with clear instructins on how to do this please? Many thanks
Instead of removing and switching the door go to www.applianceart.com
If you don't find anything there go to www.dishwasherart.com
These guys make covers to go over your existing door--- they have solid colors, designs, textures--- you name it these guys have thought of it when it comes to dishwasher decor.
And with the holidays rapidly approaching they have options for all.
Call these guys-- they will help you with all options.
Oct 23, 2011 | Dishwashers
Trying to remove the decor door from my Tecnik 795/3. Removed the top two screws along the top of the door, and also the two long side screws half way down the door. It won't budge though so wondered...
I am not sure about which way the door comes off but I know of a company called Appliance Art that makes covers for existing appliances.
These guys have all kinds of colors, textures, designs and stainless options for refacing your dishwasher--- then maybe you can save the hassle of removing the door at all.
Sep 24, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
The door of my Miele G646 SCI semi-integrated dishwasher has suddenly become stiff to move up or down. I am guessing there is a problem with the spring? Any suggestions what to try or how to get access?
Most probably the decor door has swollen and catching on adjoining cabinets. removed decor door via two screws down the left and right hand side of door and see if that helps. If springs snaps then the door will drop very quickly and take the skin off you shins
Jan 14, 2011 | Miele 24 in. G646SCi Plus Free-standing...
How do you remove a rear door panel on an Audi A3 4 Door
- Door trim.
Removal
- Unclip decorative panel -2-.
- Remove decorative panel -2- toward front.
- Remove bolts -3- (3x) from door trim -1-.
For vehicles with electric window regulators
- Window regulator switch, removing and installing Page 70-25 .
For vehicles with manual window crank
- Manual window crank, removing and installing Page 70-26 .
For all vehicles
- Unclip door trim -1-. Replace damaged clips Fig. 3
- Raise door trim -1- upward approx. 20 cm. out from door shell.
- Disengage Bowden cable for interior door mechanism Fig. 1 .
- Disconnect electrical harness connectors Fig. 2
Dec 03, 2010 | 2005 Audi A3
Without the decor panel on the dishwasher the door keeps springing back will this stop when we fit the decor panel
Normally there is a way to tighten the springs on the two sides of the doors. This is to compensate for the decor panel. If you don't have the decor panels you could ease the tension slightly by adjusting the spring nuts and that should stop the door springing back.
Will need to know the exact make and model of the dishwasher to work out the exact location of parts etc.
Oct 23, 2010 | Dishwashers
Need to remove decorative door panel
There are two main ways to remove it.
  • There should be screws on metal trim the side and or bottom of the dishwasher door. Take those out and it should come right off.
Or
  • There are screws on the back of the door screwed in to the front of the door. Remove the screws and it should come off.
Now this is say IF it was installed properly and not clued or screwed on by just anyone.
Good luck. I hope this helps.
May 30, 2010 | Bosch SHV68 Built-in Dishwasher
How do i remove the decor door from my integrated dishwasher. The instruction manual refers to a small tool that I can't find (we moved into the house with the dishwasher already here) thanks for your...
I do not know the make or model of your Dishwasher but on most makes the screws on the inside edge of door are utilised.Normally the bottom edge and top edge,sometimes you can tell by the type of screw head or rust.Some model may have a small plastic plug in the side edge of door and if removed you will gain access to the screws.
Hope this helps.
May 29, 2010 | Dishwashers
Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
call for service to change the outer panel.it takes about 15min.
Feb 24, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Bosch 24 in. SHV55M03GB Built-In Dishwasher Logo
812 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
