Question about Ertl Premiere Case IH Model 8920 Tractor
Hi there, i have a case 8920 magnum, the 3 point hitch displays a "p" when i want to raise or lower it
New Holland tractor
Sensor, wiring or computer failure.
Jun 26, 2016 | Cars & Trucks
Farmall 856 hitch does not raise in zero weather
ck to see what hydraulic oil your using , I bet it's an all weather rated oil, if temp is below zero then that's out of "all weather" range , you will need to look into using a cold weather rated oil (ck with you local dealer to ask ), my tractor has an oil bypass lever you can engage on the valve block this allows oil to circulate around in loop to heat up (+20 degrees) to work in cold temps , I don't think a 856 has one of them
Jan 21, 2016 | Farmall IH Tractor 706, 756, 806, 856,...
Deere 5525 control stick is difficult to pull back
Are you talking about the three point hitch lever? Does it have a cable going to the three point hitch spool valve? If so, try spraying penitrating oil in the cable at both ends.
Jan 02, 2015 | Garden
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE, NOT SURE WHAT CONTROLS OPERATE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
May 07, 2010 | Garden
How to install a 3 point hitch on a 140 farmall did not come with a 3 point hitch
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it.
GOOD LUCK
Mike
Oct 16, 2009 | Garden
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
3 point hitch wont lower
Some of these tractors have a knob under the seat that locks the three point up so it cannot be lowered by accident. Check for this knob and open it.
Mar 27, 2009 | Garden
Ertl Premiere Case IH Model 8920 Tractor Logo
214 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
