Question about Stiebel Eltron TEMPRA 36 Electronically Controlled Tankless Water Heater
3rd camber light not on. Hit reset button. Seems to work now. Is this a common problem with this unit?
  • 12,061 Answers
Www.stiebel-eltron-usa.com/pdf/partslist_tempra.pdf
Above is your service and repair manual, below is your support link.
www.stiebel-eltron-usa.com/tempra.html
No not a "Common" thing, however any microprocessor based unit can and will suffer from "Glitches" and "Hang Ups" that's just the "Nature" of a Micro, if something goes awry that it cannot handle it will freeze. thus requiring a reset. I have seen this on many WHs with NO ill effects, however it also may be a harbinger of doom so to speak too.
Now, if it has never done such a thing before then this may indeed be a prelude to a sensor, or even a microprocessor problem-to-come?
Of course it also may not. You need to check ALL connections, sensors, etc, and give it the "Once over" use the service manual to assist.
If nothing can be discovered, then it will simply pay to keep an eye on things, and if anything does come up, then at least you will have a copy of the service manual, to help.
Posted on Apr 04, 2011
I have a Rheemglas 250 litre electric hot water system. It seems to have stopped working. Is there anything I can try to get it working again? Otherwise I'll need a technician but hoping it's...
Make sure you have power to unit. Check the breaker in your breaker panel and look around unit for a timer or disconnect that may be having problems. I don't know if you are electrically inclined so if you are scared to take off front panel, don't do so. If you believe your breakers and/or any disconnects etc., are on and working, you can remove the screws holding the inspection panel on and press the reset button on the thermostat. There may be insulation covering the thermostat. The thermostat should have a plastic cover on it shielding the live wires while making it possible to press the reset switch. Again, if you are electrically inclined, you can check for power at the thermostat. These are the simple things you can check. If you reset the button, within about 3 to 5 minutes, you should here noise from inside the unit if it is working.
Jun 05, 2011 | Rheem 81VP6S/430126 Water Heater
How does the reset work? I am helping a friend troubleshoot his water heater. One of the wires that connected the pig tail to the power block fried inside the water heater cover. I decided to remove the...
The reset button is set up to open the circuit if excess current is drawn by a failed Element. It works by getting hot and switching off due to current above its rating. The burnt wiring more llikely happened over a period of time because of a resistive joint in the block getting hot due to the high current that water heaters consume. It seems that the element has failed if the reset button does not get the system working.
Sep 17, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
No heat, no light, has flow and power?
I'm experiencing the samething it's been installed 3 years and christmas day nothing. Please help.
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
Titan SCR2 Stopped working.
I have the Titan SCR2 N-120. You may have a different model. On mine if you are looking at it just a inch below & 1 inch to the left of dead center will be a round black sticker(it has some white lines like at&t's logo). there's a pin hole in the middle of the sticker that you can poke to reset. Or turn the breaker off then take the 2 screws out of the top of the unit. It's just a thin metal cover that you can pull back & look inside. You'll see a red circular button thats the reset button. It's right behind where the hole I was talking about & what gets pushed in. you'll also be able to see if anything burned out & can get replacement parts at titanheater.com . One of my heater elements had burn/ melted & I've ordered a replacement. It was $17 + $11 s&h but still cheaper than $200 new unit from e b a y. Best of Luck
Sep 03, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
No hot water have to take cover off and hit reset button
The thermostat is going bad and needs to be replaced. Also look for water leaks that could be causing a short to the thermostat. If the tank is leaking, replace the unit.
Aug 24, 2009 | Water Heaters
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
Stiebel Eltron TEMPRA 36 Electronically Controlled Tankless Water Heater Logo
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
