Question about Chi Ionic Single Pass 1 inch Ceramic Flat Iron Sparkling GF1121 Limited Edition
The silicone strips fall out of the flat iron every time i straighten my hair. Is there any way to keep them from falling out?
BABNT2091T
The Problem with BaByliss PRO Nano Titanium 1" Ultra Thin Hair Straightening/Flat Iron can be resolved if you call the company support line or web page.
May 10, 2014 | BaByliss PRO Nano Titanium 1" Ultra Thin...
Tip
TOP TIPS FOR HAIR CARE
ost people think about preventing hair loss only after they have lost a lot of it. But if you start early (like when you still have a head full of hair) it works out a lot easier both emotionally and financially. In fact, the truth is - preventing hair loss is a simpler process than treating hair loss. Plainly put, it all boils down to some sensible hair care - if you take care to keep the hair you've got, you will be blessed with better looks and healthier hair. So here are a few things you can do to prevent your hair from falling:
1. Follow a healthy lifestyle,
2. Take care of your hair,
3. Avoid things bad for your hair, and
4. Adopt simple Home treatments.
1. Follow a Healthy Lifestyle
Hair, like your skin and your nail, is often a barometer of general health. If you are healthy, your hair will probably look good. And if your hair is falling, it could be a sign of possible health problems.
So everything you do for good health also applies to hair: eat your fruits and vegetables (Vitamin B, Iron, Calcium and Zinc have especially been linked to healthy hair); always consume a protein-rich diet (hair is made of proteins), and drink adequate water.
Dirty hair is more likely to get infected and more likely to fall - so keep your hair clean. Buy good-quality shampoo and hair products (in the long run this is cheaper than treating hair that is already half gone). When you shampoo your hair, concentrate on the scalp and hair roots. When applying a conditioner or hair lotion, it is better to concentrate on the ends of your hair (which tend to dry out faster and are more vulnerable to the damage that comes from exposure).
Trimming you mane regularly helps your hair look and feel better. Besides, it's also a long "bye-bye" to those annoying split ends!
How to Prevent Hair Fall - Slideshow Quiz On Hair Loss
3. Avoid things that are bad for your hair
This seems so obvious it should not need telling. But it apparently does need to be told again because many of us unknowingly adopt several unhealthy hair-practices:
Wearing styles that pull the hair tight (usually into braids or pony tails). Many women pull their hair so tight it actually comes out of its roots. If you change your hairstyle soon enough, your hair will recover. Otherwise, your hair might permanently stop growing from the areas it is pulled most from.
Any chemical treatments (even so-called 'herbal' ones) designed to drastically change the way your hair looks (styling, perming, straightening, hot-oil treatments, hot ironing).
Blow-drying your hair - this dries out the scalp and damages hair follicles. Allow your hair to air dry at least part of the time, or change the heat setting on your blower to the lowest.
Combing your hair or rough toweling when its wet - this will put out some hair strands from the roots and stretch and break others
Even the habit of pulling out hair might do more harm than you realize (some people actually go bald from this).
The idea is to be gentle with your hair. Do nothing that might harm your hair in any way.
4. Home treatments for healthy hair
Here we've mentioned a few home treatments that generations of Indian women have relied on. Give these ancient secrets a shot yourselves!
Make a paste of henna, curd, soaked and ground fenugreek, ground hibiscus flowers, ground gooseberries, and egg (all of them or any one) and apply it onto the hair and scalp for about an hour before shampooing. Done regularly, this will make your hair stronger and better-looking. But remember that henna is suitable only for dark colored hair because it tints hair red.
Wash the hair out with decoction of tea or a bit of lemon squeezed into the water in which you will bathe. (for dandruff).
Apply coconut or almond oil. If doing this daily does not appeal to you, apply the oil on the scalp overnight before shampooing, or apply a drop to the top of your head before you comb out your hair.
Never ever take your hair for granted. The adage "Prevention is better than cure" fully applies to your hair too. Remember, you will sorely miss those beautiful tresses if you let them go away!
on Jun 25, 2015 | Miscellaneous
Tip
Fight hair fall with natural ingedients.
In summer we sweat a lot. Our head is no different. Due to excessive sweating hair may fall and can create a concern for you. Here are 5 remedies you can try.
1. Mix 5 teaspoon coconut milk, 1 teaspoon Indian gooseberry (Amla) juice, 1 teaspoon water melon juice, 1 teaspoon tender coconut water and 1 teaspoon lemon juice together. Apply this mixture on the scalp and hair. Keep it for 20 minutes. Then wash it off with cold water. You can prevent hair fall.
2. Mix cucumber juice, tender coconut water, raw mango pulp, Indian gooseberry paste, fenugreek seed paste and egg yolk together. Apply this mixture to your sculp. Keep it for some time and wash it with normal water.
3. Due to dandruff hair may fall. The day you put anti dandruff shampoo your scalp is free from dandruff. The same day you must wash your comb, towel and pillow cover with anti-bacterial solution like Detol, Savlon. So dandruff will not come back from these things.
4. Aloe Vera gel is very helpful for hair. It gives nourishment to hair in many respects. It is very easy to collect the gel. You have to just open up the thick leaf from one side. For one person 50 grams of gel is enough. You have to rub the gel all over your scalp and keep it for 10 minutes. After that wash your head with plain water.
5. Please, do not comb your hair when it is wet. Ladies should not make knot when the hair is wet.
on Jan 18, 2011 | Health & Beauty
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
Tip
Routine care at home to prevent the hair from damage.
  • Always keep your hair clean. It will protect them from dandruff, itching and hair lice, which ultimately results in hair fall.
  • Always use the shampoo and conditioner depending on your hair type. As for oily hair, you should use a shampoo, which is meant for specifically for oily hair.
  • Give regular massages to your scalp and hair with lukewarm oil at least twice a month. You can choose coconut oil, olive oil or almond oil for your hair. You can even mix these oil and apply the solution on your hair.
  • If there is dandruff in your hair you can mix camphor cubes in coconut oil to massage on your hair and scalp. It helps in reducing the dandruff.
  • Rub a lime on your scalp if there is dandruff on your scalp, leave it for 10 minutes and shampoo the hair. You should use medicated dandruff shampoo and oil to apply on your hair when they are suffering from dandruff.
  • Never comb your hair when they are wet. The roots of the hairs are the weakest when they are wet.
  • Keep the hair wrapped in a towel for a while then let them dry in natural air as excess usage of hair dryer too damages the hair texture and makes them weak and then ultimately they fall.
  • When your hair is falling, make a mixture at home containing Amla, Shikakai and dry neem leaves. Grind them together and apply this paste on the hair before washing them off for a while.
  • Whipped eggs mixed in curd and henna powder help in preventing hair fall.
  • Eat healthy diet including green vegetables, dairy products and fruits.
  • Drinking coconut water prevents the hair fall.
  • You can make oil at home for falling hair. Boil henna and neem leaves in mustard oil till the leaves get almost dissolved in it. Let it cool and then filter. Add few camphor cubes to it and fill in a bottle. Use this oil to massage on your hair.
  • Mixture of almond oil, olive oil and castor oil is equally good to prevent and stop hair from further falling.
  • Get your hair trim every month so that there are no split ends left.
  • Include at least 2 nuts in your daily diet. They help a lot in strengthen the hair.
  • Avoid using too harsh clips or bands on the hair. Never make hair too tight.
  • Protect the hair from dust and sun. Cover your head while going in the direct sun.
  • Apply hair pack on your head at least once in a month. It can be henna paste, curd, eggs or a combination of all.
  • Wash your hair every time you apply some chemicals on your hair in form of styling gels, creams, sprays or lotions. The harmful chemicals in them damage the hair and make them to fall.
  • If you have got the bald patches on your head then apply onion on the bald patch by rubbing it and then apply honey over it. Leave it for few minutes and then wash off.
  • Boil fenugreek seeds in any of the hair oil of your choice as coconut oil or olive oil. Restrain it and fill it in a bottle. Use this oil to massage on your head. Its very helpful in reducing the hair loss.
  • Eating iron rich fruits and food helps in preventing the hair fall. Include apples, beetroots and jagary in your daily diet. They are rich in iron so help to prevent your hair fall.
  • Eating amla in any form or drinking its juice too helps in preventing hair fall.
Follow these simple hair care tips and you can protect your hair from further damage
on Jun 30, 2010 | Health & Beauty
How do you use a conair straightener? what does the dial with the numbers mean?
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
May 31, 2011 | Conair Health & Beauty
Rear passenger sliding door wont shut?
Check the bottom weather strip along the frame, it's common for passengers to knock them off it's runners and they fall down preventing the sliding door to close properly.
If it is the weather strip, place some RTV silicon to keep it in place when you re-install the weather strip back in place.
Thank you for using fixya and keep me posted, be glad to help you get your sliding door working 100% again.
Apr 19, 2010 | 2003 Chevrolet Venture Passanger
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Chi Ionic Single Pass 1 inch Ceramic Flat Iron Sparkling GF1121 Limited Edition Logo
174 people viewed this question
Top Chi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Chi Health and Beauty Expert? Answer questions, earn points and help others
