Question about Bose 35504 Remote Control
My Model RCV1T-27 remote will go through a set of AAA batteries in 2 weeks. We only use the remote in the evening and then only to turn on the system and set the volume. All the channel changine is done throuth the cable system remote. Is this normal battery life?
If I am lucky, I get 3 days with a brand new set of batteries. Actually, I rarely ever use my system for that very reason. the irony is i chose this model based on the radio frequency feature. . .what a fiasco.
Posted on Apr 25, 2011
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
Bose remote control not working
Check the remote control for its infrared emission. If it is not found OK, clean the remote control. Open it and clean the PCB inside it. Check the batteries too. Check it with fresh batteries.
May 25, 2013 | Bose RCV1T-27 Remote Control for Lifestyle...
The battery life for the remote for my Hampton Bay fan, Model cf556br-crk only lasts 3-4 weeks. It is 12 volt and should last longer. Any solutions?
More info,please.
there are always solutions to a problem. Usually 4.
I have to dig around the internet to see what batteries these take..
Hold on.
The remote control takes 4 AAA cells.
Try Energizer E2 batteries. They are the longest lasting batteries available.
Lithium.
If the remote dies in 4 weeks or less,the remote is at fault.
Probably a factory recall for those remotes.
Try pulling one of the batteries out when not in use.There may be a power drain,internally ALL of the time.
Feb 18, 2013 | Hampton Bay Dryers
I brought a remote and put in 2 AAA batterys and it was small
what was small, the remote you brought or the 2 AAA Batteries? if the 2 AAA batteries are small try the medium size batteries. GOOD LUCK!!!!
Oct 05, 2011 | Televison & Video
My Bose V30 system with the RCV1T-27 remote wont send the IR signal to my Motorola DCT 6416 if im not standing right in front of the Bose display unit. The light on the display still blinks as if its...
Hello
Check the cells in the battery compartment of your remote control handset. Replace it with new ones and check. Still you poise this problem, the intensity of infrared rays come from your remote control, or the sensitivity of the infrared sensor inside your bose front panel system may have the trouble. Just replace the infrared LED of your remote control with an other one of same type. If it does not helps you, repalcing the infrared sensor will reftify your problem. OK.
May 05, 2011 | Bose Lifestyle V30 Home Theater System -...
Batteries need changing about every 2-3 weeks !!
Three options
1. take out the batts, press every button twice and put new ones in
2.call logitech and see if they will replce it
3. take that baby back to the store and get a new one
Jan 24, 2009 | Logitech HARMONY 659 Remote Control
Do not know how to replace batteries on Celestial Air Con remote
I had a similar issue and found this thread.
I pulled my the slider down on my remote to the reveal the hidden buttons and then pressed the 2 side thumb grips inwards on either side on the slider and pulled it down again. This popped it off the slider and thus revealed the 2 flat AAA Batteries!
Jan 12, 2009 | Heating & Cooling
Code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
Sep 02, 2008 | Bose RC-18S Remote Control
Bose 35504 Remote Control Logo
541 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Jerry Greenberg
Jerry Greenberg
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
