Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I need to reset my roater - D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
  • 2,632 Answers
Welcome to Fixya. If you want to reset the router all you need to do is to press the reset button at the back of it for 5-10 seconds using a pen or paperclip. Make sure that the router is turn on and you will see the light will start flashing when you poke the button.
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 03, 2011
How to connect to the internet
Hi this is Alex Walker expert to help you for this Issue Call +1(404)981-1535 I will be glad to assist you
Dec 27, 2015 | ASUS Eee 4G Notebook
The passenger airbag sensor is not sensing lighter passengers, the airbag stays on when we need it off.
What is a roater to the horn ? Horn stopped working ... Guys says its a roater I need??
Feb 16, 2013 | 2012 Ford Focus
My broblem is, i have a signal from in my broadband roater,but my computer canont get it the signal from my roater. please help me about this broblem.
Kindly check the configuration of your router and to your computer..probably it has a problema to their ip address, if not check the cables to the router and test your utp if you have cable tester so that we can check if the connection is okey to get a signal to your router to computer.
Sep 16, 2011 | Computers & Internet
Brakes suddenly started grinding on one side. can see scraping on plate that surrounds brake
YOU NEED TO CHANGE OUT THE BREAK PADS, ALSO YOU MOST LIKELY DESTROIED YOUR ROATER...Do not just change out only one roater even if the other side looks good. overtime the roaters where down if you replace only one side it will pull to that side.....After you have new ones installed if the truch feals like it is pulling all the time to the same side you are haveing probleams with then most likely you will need a new wheel cylender also....Good luck I hope this helps
Dec 03, 2010 | 1995 Jeep Grand Cherokee
When you come to a stop. car squeaks. only after engine gets hot when cold does not. it is 2002 dodge intrepid 2.7 engine. put new roaters and pads on front also checked back roaters and pads they are...
You will need to dig deeper. Check that the front and rear wheel bearings are smooth and tight, check each wheel for drag. pump the brake up and spin the wheel, one by one (how are they?). When you inspected the brakes what did the rotors look like? Were any of them blue in color? Did any of them have a ridge of rust on the outer and inner edge? Did you look at the old pads and see if they were waring evenly? Did the cylinder compress into the caliper easily? Did you inspect and service both sliders. Only use synthetic brake caliper lube, The non synthetic stuff doesn't last and never seize is a big no no. let me know, good luck.
Apr 21, 2010 | 2002 Dodge Intrepid
Jeep stalls and has no spark
try the ignition module... thats what controls spark to the coil...
Aug 08, 2009 | 1997 Jeep Grand Cherokee
I can not connect to internet throught wireless roater
as no router name is given try going online with the ethernet connection 1st of works get the wireless key , and change the wireless channel to higher frequency  for xp start-control panel-switch to classicview- network connection -wireless network connection -right click -ciew avail netwiro connection . select ur network - click connection add the key and ur connected vista start-ctrl panel- classic view- network and sharing centre - manage network connection- wireless network connection- right click connect or disconnect -security or phass pharase enter the wireless key u r connected  its fixya
Nov 01, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Rear wheel bearing
go to your closest auto store. for this you need a very large rench. there should be a bolt that doesn't really look likt a bolt behind where your roater sits. then auto store will know the exact size. i prefer auto zone.
Jul 07, 2008 | 1996 Ford Escort 4 Door
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
