Question about Kenmore Washing Machines
I have top load washing machine with a model # 110 24902200 Ser # cm4505410 type 111 and it leaks water out the bottom when I wash jeans or towels or a heavy load. Why and how can this be fixed?
We had the same problem. The drain from the bleach input is clogged (water cycles through the bleach tray even if you don't add it at a certain point during every cycle). Use a wire hanger or something like it to poke the lint out of the drain (take the bleach tray out first).
Posted on Oct 26, 2011
  • 3 Answers
Even washing machines hafe to take a leak or were i am from we call it ****
Posted on Apr 03, 2011
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
All funcions of the washer work except the drain at the end
is your drain hose kinked near the back of the washer. try to look behind the washer without moving it. if the hose is not kinked its probably the pump..
Feb 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
118 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
