Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Dose it has a filter and my hot water wont work only cold
  • Whirlpool Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Apr 03, 2011
I replaced the hot & cold water valves on my LG Washer/Dryer .Now it just humms and no water goes into the washer..What can cause this problem?
have you tried both the cold and hot?hot only has one solenoid while the cold has three.just because it is a new part dose not mean it is not mean it is a good part.try this,turn off the cold and hot water,remove the cold hose from the washer and put it in a bucket and turn it on at the hose bib.if you do not get water,you may have a screen in the hose bib end of the hose.if no screen on that end you may have a metal fitting rusted up just under the hose bib.check the hot side also.hope this helps,if not repost and i will try to dig deeper.thanks
Mar 15, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Turns no no water in .pump ok makes as if its going to start but dose not.
'No water in'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 23, 2011 | Washing Machines
No cold water enters tub. Everything gets washed hot no matttter what the setting.
You water line filters may be stopped up. This happened to me once and I unscrewed the two hoses next to the machine and looked. There was a filter that I could remove, made of hard plastic. I took the filters out of each hose and screwed the hoses back on the machine, without the filters. It worked for years. The other thing that I have done is I once had a machine I couldn't get unclogged and the line didn't work for my cold water so I turned off my hot water and I took the hot water hose and put it to the cold water tap. My cold water came into the machine by the hot water hose. I used it for years afterwards. I just had to wash everything in cold water.
Jul 16, 2011 | Siemens WFXD5200UC Front Load Washer
Fisher and paykel Smart Drive 608 dose not fill with water
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jul 05, 2011 | Washing Machines
There is no water reaching my AprilAire humidifier, indeed no water is flowing through the saddle valve attached to the hot water pipe of the hot water heater. Considering what would be involved in...
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
Dec 22, 2010 | Aprilaire 550 Humidifier
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
2000 olds bravada the heat dose not get hot or cold stay the same i switch it to hot or cold dose not matter what could it be
Hello the bravada and the s10 blazer are bad about the heater cores air locking or either stopping up. Disconnect the heater hoses at the firewall and run a water hose to the inlet then try the outlet until the water is clear of debris then reconnect and refill with coolant remember 50/50 coolant water. Pure coolant will freeze and so will pure water. Thank you
Feb 22, 2009 | 2000 Oldsmobile Bravada
About a indesitwi101
if your machine is cold water fill only thats because the machine will heat up the desired temperature for you
Feb 02, 2009 | Indesit W 123 Front Load Washer
Cold water line
replace water valve and fill hoses
Mar 21, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
