Question about Soundcraft E8 E Series 8-Channel Mixer
Hi My soundcraft worked fine, then after 3 months of not using it, I plug it in and it won't go on. I changed the fuse at the back by the mains lead, but it still doesn't go on. I faint regular clicking sound is heard from the desk when it is on but no signal and no power light on. It is a Soundcraft Spirit E8 Many Thanks, Barnaby Archer
5 Suggested Answers
  • 5603 Answers
SOURCE: Please help. Cannot turn the
Check the fuse. If it has blown, do NOT replace it without taking for service first. Additional damage often occurs when users replace fuses that have blown due to internal failures in equipment.
Also check that the power cord is fully seated... sometimes they don't quite make it...
Posted on Feb 05, 2011
  • 5603 Answers
SOURCE: Soundcraft EPM12, need power suply schematic
This isn't your model BUT it is likely so similar as to be close enough to work a power supply problem.
http://elektrotanya.com/soundcraft_folio_f1-6-i-p_mixer.pdf/download.html
These companies don't change designs very much between different models.
Posted on Feb 08, 2011
  • 5603 Answers
SOURCE: Soundcraft, Compact 10. Problem:
This is probably close to your unit:
Scroll down to "get Manual" and click on it. Circuitry is so simple... they don't show the transformer, only the rectifier and regulators.
Posted on Apr 26, 2011
  • 5603 Answers
SOURCE: Soundcraft GIGRAC 600 pre-amp power
The resistor is acting as a fuse and will continue to blow until you fix the REAL problem. LIKELY the filter capacitor(s) beyond the bridge rectifier are failing. One needs to use test equipment to measure the current through the resistor and see if it is reasonable. The capacitors can heal briefly and then start to short. One should also check the rectifier in operation with an oscilloscope as one diode could intermittently short.
Posted on May 04, 2011
The effects will not work for more than 10 or so min, then quites
Unit needs to be serviced by qualified technician. If you have some knowledge and experience, do this...use a Freeze spray (available at your electronic parts dealer) and freeze the effects related parts 1 at a time till they come back. No Freeze spray? When stops working, physically feel related components immediately for excessive heat.
Feb 02, 2018 | Soundcraft Music
AMPLIFIER CUTTING OUT WHEN SOUNDCRAFT EFX8 GOES INTO HIGH LEVELS
Hi Terence!
Check your Amp Frequency Ratings and also your power supply.
Increase the high levels gradually until cut-off.
Try reducing your output level at the EQ to match the Input Level at the AMP. What Brand & Model Amp is it plugged into?
Here is a link to EQ manual of operation.
Good Luck,
JP
SoundCraft EFX8 Manuals
Oct 14, 2015 | Soundcraft Music
The right channel on the headphone out does not work
Do the headphones you are using have a stereo plug. I find most times people are using a mono adapter plug of some sort..It needs to be a stereo plug. If it is, then contact this site and they can help with the proper parts to repair http://www.prosoundservice.com/
Apr 02, 2014 | Soundcraft *new* Soundcraft Epm8 Analog...
Soundcraft efx 12
Good luck. Your mixer only has one aux out to supply only one stage monitor out. Only way to make it work would be to use the panning controls of each channel to different outputs to the Left and Right main outs for stage monitors and aux out as front of house speakers. I would get another separate mixer for monitor such as another efx 12 with every input connected to both mixers, then use the panning and main outputs to that. Sorry. Just not enough of mixer. You need an aux out for each individual's monitor.
Jan 13, 2014 | Music
My Behringer PMX (or PMH?) 3000 powered mixer won't power on
Hi Robert,
The problem with ceramic fuses is that you can't tell if it's blown unless you put a meter on both ends to check for continuity. You probably have a friend that has a multi-meter sitting in a drawer somewhere, or a trip to the local Radio Shack will tell you right away - as well as likely finding the correct value fuse. Replacing it with a ceramic is not as critical as matching the AMPERAGE of the fuse (the Behringer site might be helpful: http://www.behringer.com/EN/Support/Find-Answers-or-Ask-Behringer.aspx
And no, the fuse didn't die on it's own, but are most prone to failure at turn on - so this time when you plugged it in after 3 years - it was time to go.
Mar 16, 2013 | Music
Soundcraft GIGRAC 600 pre-amp power supply keep blowing the low valve resistor 1ohm. they are the resistor just before the bridge rectifier, for the low voltage feed. Once resistors replaced the unit...
May 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Hi ihve soundcraft efx12 & the problem is in the effect, it hanges if i use the program selector, all the leds related to lexicon effects lit up.ithink the problem is in the the lexicon card. please...
If the LED's are level indicators, you are probably saturating the input of the effect and may cause it to hang. Effects use delay and feedback and can cause numerical overflow and the system to basically crash. I would first call the Lexicon support and ask them about this problem... I did have to return one Lexicon product myself for service under warranty.
Mar 25, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Hi - when I power on teh board the speakers start clicking - at first it was a very loud popping sound but now it is just a semi loud clicking but it is constant
Make sure you use BALANCED interconnection cables and the board is powered from the SAME receptacle or source as the speaker/amp.
This board is very simple and if the source of the noise is in the unit, I would look to a problem involving the Phantom power supply. The Phantom connects to the mic inputs and if it gets noisy it will often couple into the inputs.
Unplug ALL inputs to verify it is not coming in via the mics. Does the main fader control the loudness?
Here might be your schematic:
http://elektrotanya.com/soundcraft_e8_mixer_sch.pdf/download.html
Feb 28, 2011 | Soundcraft *new* Soundcraft Epm8 Analog...
Soundcraft EPM12, need power suply schematic pls.
Feb 07, 2011 | Soundcraft Epm12 Analog Mixer - Epm 12
Please help. Cannot turn the soundcraft gigrac 600 on.
Feb 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Soundcraft E8 E Series 8-Channel Mixer Logo
194 people viewed this question
Top Soundcraft Music Experts
rhodesworks
Tom Rood
Level 1 Expert
Are you a Soundcraft Music Expert? Answer questions, earn points and help others
