Question about Proform 560hr Treadmill Walking Belt
When i turn on my treadmill it makes a strange sound then the trip switch goes on my electric box..only bought it today second hand and i really need it as i hav had 3 spinal fusions and neck fusion and have put up lot weight due to no excercise as hard battle recovering ....i would be very greatful for any help please as i really need it and i cannot afford to buy a new one so any help would be great many thanks
    Habit-Forming:
    New Friend:
  • 36 Answers
    New Friend:
  • 79 Answers
Advanced Spinal Fusion Surgery In Los Angeles
Dr.Todd Gravori performs spinal fusion surgery in LA using advanced technology & surgical procedures. Schedule an appointment calling on 310-278-7000.
Know more here: Spinal Fusion Surgery In Los Angeles ProMedSpine
Posted on Oct 20, 2015
    Top Expert:
  • Proform Master
  • 12,223 Answers
when i turn on my - 12_7_2011_9_47_46_pm.gifPlease observe the block diagram that I did for people like you. Now you will have a great Idea how going on in the treadmill. example: 1possibility: Capacitor in short 2) Coil in short 3) Main Motor short 4) Main Motor controller board short.
Now you will have a voltemeter and make the test.
Alternatives #2
Finally I am suppossing the electric box is from your house. In that case there are not the problem mentioned before since the treadmill has internal fuse will be trip. So you can test the power cord, if some wires is touching with the other, or if the ground in Outlet from you wall is Not o.k that produce a Ground. Please do not use extension cord, that extension there are NOT good dimension by carrier enough amper aprox 20amp, this will be strip the BREAKER or fuse in your house. If you have a doubt call a electrician to inspect your ground where you connect the treadmill. sincerely.
E.CUADRA
MANAGUA, NICARAGUA.
Posted on Dec 07, 2011
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
I have a proform crosswalk 400e, and the circuit breaker on the treadmill trips whenever I plug it in
Many motor may have two stages, the first starts it turning and then the second stage takes over to keep it running. The 2nd stage of the motor may be faulty and drawing two much current or leaking current to the earth. Your breaker may not be the correct rating for the machine and needs uprating.
Something could have slipped in or moved around that could be jamming the belt or something else in the machine preventing it from starting up and causing an overload that triggers the breaker.
Feb 15, 2015 | Proform Crosswalk 400e Treadmill Total...
Please can anyone help me I bought a 560hr treadmill today second hand it was workin perfectly, until my son and grandson went on it ..it now will turn on but the belt will not go it trips the power switch...
12_7_2011_9_56_59_pm.gifSee the block diagram that I did for you. Now you will see how many elements or component has the treadmills. If the fuse or breaker are trips. you must inspect and test: 1) Power cord some internal wires is touching insider and produce short-circuit. 2)Capacitor in short 3) Coil or transformer in short 4) Main Motor in short 5) Main Controller Board.
Finally see for any wire is loose and touch the chassis from the machine in that case produce a BIG SHORT. sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
Hello all I have a GE DCLR333ETOWW Electric dryer. When we got it the start button was missing so I had the Blue and Brown Wires sticking out and we would just touch them together for a second and the...
first things first. Electric dryers are 220v on a double breaker in your breaker box. (120v for the motor,120v for the heater element). When your dryer sparked, it probably tripped the breaker. Note: you REALLY need to buy a switch an get those exposed wires back inside of the dryer where they belong...just sayin'
Apr 30, 2017 | GE Dryers
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Just bought my son a 1996 jeep cherokee. Today it
If the starter is getting proper voltage at main lead and trigger wire (with the key in "start") pull the starter. If it was making strange sounds likely there is something wrong with it. Check flywheel as well and make sure you can turn the engine by hand. If you aren't getting the proper voltage, check the battery, connections and starter relay (in power distribution center)
Dec 01, 2009 | 1996 Jeep Grand Cherokee
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Proform 560hr Treadmill Walking Belt Logo
385 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
