Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
No power when I switch on computer. Fan not running, power light not coming on. Have tried plugging in to different socket. Still nothing. Taken case side off, double checked all fittings. Cleaned computer interior & fan. Still dead.
  • E-Machines Master
  • 5,660 Answers
If you know the receptacles that you have plugged the computer into, indeed have power, I would suggest you diagnose the Power On switch, and the Power Supply.
See of the problem is the Power On switch, or the Power Supply.
A jumper wire is used on the main ATX power cable.
1) If the Power Supply comes on you have a bad Power On switch.
2) If the Power Supply does Not come on, you have a bad Power Supply.
Your problem is posted in the eMachines Bestec ATX-300-12E power supply section.
Going with that we are discussing a Bestec ATX 300 watt power supply, the main ATX power cable is a 20-pin ATX main power cable.
Typical pinout of a 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note the Green wire in the BACK of the connector, in the photo to the far right.
This is the Soft Power On wire, or also abbreviated as the PS_ON wire.
Note the Black wires. ANY Black wire is a Ground wire.
With the 20-pin ATX power cable plugged into the motherboard, as shown in the photo, a jumper wire is touched to the Green wire, and to ANY Black wire.
The computer (Power Supply) is also plugged into power.
Generally a paper clip is used for the jumper wire.
The paper clip is straightened out, then bent into a U shape.
Black plastic electrical tape is then wound around the middle of the U shape.
This taped area is for your fingers, and thumb to hold onto.
The 'legs' of the paper clip, are then inserted down into the socket holes, in the back of the 20-pin ATX main power cable's connector.
Down into a socket hole with the Green wire, and also into a socket hole with ANY Black wire.
The 'leg' of the paper clip goes down into the socket hole, RIGHT NEXT to the existing wire.
At the end of every wire in the 20-pin ATX main power cable, is a metal terminal end.
The metal terminal end is pretty far down in the socket.
You must ensure that the metal end of the paper clip, touches the metal terminal.
The voltage is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
There may be a small spark as you make the connection.
Warning you in advance.
You can see the voltage is VERY low, however.
I would like you to perform this test, then post back in a Comment as to your findings.
Regards,
joecoolvette
Posted on Apr 03, 2011
  • joecoolvette
    joecoolvette Apr 04, 2011
    Thank you for the rating easycoustic, Most Kind!
  • 23 Answers
Is there a flat toggle switch on the back of the power supply? If so, is it in the "on" position? If there is no switch, or the switch is on, then check to see that the 20 (or 20+4) pin cable that attaches to the motherboard is properly seated. That connection is usually in the middle of the right side of the motherboard, and it is the biggest single cable coming from the Power Supply. On some newer motherboards, there is a separate 4 or 8 pin connection as well, and is commonly near the upper left of the motherboard, though it could be located just about anywhere. If all of the motherboard connections are in tight, your PC should at least turn on (POST). You can check to see if there is any power coming from the Power Supply with a multimeter if you have one and are comfortable using it.
If you don't find the problem with the tips above, then it sounds like your power supply is dead. Sometimes a PSU (Power Supply Unit) Dies unexpectedly without any real evidence, or it has a fiery/smoky smelly death. Get a new Power Supply, I suggest one with good user-ratings. There are cheap power supplies that look like they can handle what you have, but they tend to not last long.As a rule, I don't spend less than $40 on a PSU unless I plan on replacing it soon.
My hp pavilion desktop pc power cable is plugged in but when I push the power button it does nothing
most of those hps have a light on the back on the power supply that lights when its plugged in but not all. I would try plugging it in on a different outlet to be sure its not a power strip or bad house socket. Make sure if it does try to come on that the power supply fan is turning. I would also take the side cover off and make sure that the wires that plug in the switch have not come loose
Dec 13, 2013 | Computers & Internet
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
I have a hunter ceiling fan model 23898 which has a dimmer switch built in one day a light bulb blew out on it and now we cannot turn off the lights with the switch the only way is to loosen the bulbs in...
Has anyone found a solution for this problem? I have tried a bulb in each light socket and attempted to use the pull/dimmer switch that is on the fan itself. The lights no longer dim nor turn off. I have unscrewed all of the bulbs and tried each bulb in each socket one at a time and still nothing. I have also taken the pull switch out of a different hunter fan to put into this one, hoping that atleast the lights would turn on and off. Still the lights won't turn off using the pull switch. I am out of ideas.
Sep 11, 2011 | Hunter Ceiling Fans Individual...
PC will not power up. No fans, lights, anything.
Have you tried a different power cord? (longshot, I know, but it is one of the variables that you don't mention)
Have you tried a different A/C outlet?
Dec 22, 2009 | Computers & Internet
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
Acer Aspire won't start
There is one common flaw with most all laptops. The socket plug for the power cord is connected to the motherboard. When you plug the power cord into this socket it applies pressure or weight on the socket inside the computer. It sounds as if your charge cord is working. Moving the computer around while it is plugged in can cause even more stress on the plug socket.
Try this...but be careful...using a small item such as a toothpick or other non-metalic item...push up and down on the plug socket. If it moves around this is not normal and probably the cause of your problem.
I fixed my laptop by soldering the contacts of the socket back down to the board. I don't suggest doing this yourself unless you know how to take a laptop apart. Check with your local computer repair shop and have them give you an estimate to either fix by reconnecting or replacing the motherboard. Hope this helps. Thanks!
Jun 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
583 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
