Question about Whirlpool AKZ159IX Oven
I have an IKEA whirlpool oven that is stuck in "STOP" mode. I have tried to switch on the electricity while pushing the middle bottom. Is it the control unit that has to be replaced ? Is it possible to repair the control unit ? (I have a technician that I can ask for help ...) Best regards, mfwallin
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Whirlpool self-cleaning electric built in oven
I have the same problem. Who has a solution?
Posted on Aug 24, 2008
SOURCE: Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Posted on Aug 01, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
SOURCE: missing instruction manual for IKEA Whirlpool oven
After a powerbrake the IKEA Whirlpooloven doesn´t work, the display just says STOP and nothing works, not even the light inside the oven. This always happens after a powerbrake and usually I can fix it after some time pressing different buttons but not today. Suggestions?
Posted on Jun 18, 2011
Oven light and "door open"
Sorry to read about your problem, I hope this helps you out.
push door tight with hand..if does not go off, you have a defective door switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Whirlpool RBS275PD Electric Single Oven
Missing instruction manual for IKEA Whirlpool oven FC SM6
Dec 17, 2009 | Ovens
Need to reset my whirlpool 2000+ cooker
Do you have a push button in the centre , between 2 dials and under display? If so, try pushing it twice then turn oven dial
Nov 14, 2009 | Whirlpool RBS275PD Electric Single Oven
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
''stop'' message on electronic programmer - Whirlpool oven
Hi
all you need to do is set clock as oven is in auto mode
to do this you need to press the middle button a couple of times
hope this helps
Mar 19, 2009 | Ovens
How do I set the clock on an IKEA oven?
Hold down the 'ok' button and it should be fairly self-explanatory from there.
Nov 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
Whirlpool AKZ159IX Oven Logo
529 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
